I don't have access to one of these machines, where do the racers ground their harnesses at? I'd guess at the top engine mount bolts. My ring terminals are 6mm (about 1/4in) for the hole, not sure what size of bolt is used for the engine mounts though. I saw I had a request for the race setup (no lighting circuit) harness for an 86 250r. Looking over my template, it looks like a nice and easy harness to make besides that ground location problem.
Also if I could get a measurement to the nearest ground location, that would be great. Using the CDI connector would give me a good base line for length, like CDI wire + 3in to reach the bolt.
The OEM layout had the ground location at the tail light area, would like to move it closer to the engine area in this harness though.
I suspect the ground location on the 85 would be the same or atleast similar. It's hard to find good photos of these machines with the tank off so I can see stuff better.
Any help would be great. I'm thinking this harness I could make for $65 shipped.
I added a photo of a near complete one. That ground wire looks so out of place being so long lol (OEM length). The pile of wire in the upper left corner is how much wire the full harness has with all the lighting wiring.
