Results 16 to 30 of 36
Thread: new 310 cylinder on 250r and all it will do is bog???
    6,811
    How are your reeds ? The 250r is one of those motors that are highly sensitive when it comes to reeds .
    You could also try going up or down some on the main jet to see if that helps .
    bushwacker51 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Jun 2003
    Cherokee, Oklahoma
    267
    38mm air stryker. has no airbox just a metal attachment then air filter. has a 175 main jet tried 178 the needle clip is second form the top. not sure on the pilot.
    Jun 2003
    Cherokee, Oklahoma
    267
    It is a cool head with high compression dome. I use race gas 112 octane. I have not checked the exhaust Ill do that sunday. I thought about replacing the reeds next. Never had one do this before. Ill stay with it until I figure it out. Thanks for all the ideas and help Glenn
    Jun 2003
    Cherokee, Oklahoma
    267
    Okay pulled the pipe and blew compressed air through it then filled with gas shook it up emptied and nothing pipe was not plugged. I pulled carb apart has a cel needle and a number 50 piolet jet. Think I might try smaller piolet and needle see if that helps. Any thoughts please let me know thanks Glenn
    Slidell, LA
    4,738
    If you still have your stock airbox and snorkel put it back on. Run a 48 pilot, needle 3rd clip from top and run a 164 pilot.
    Jun 2003
    Cherokee, Oklahoma
    267
    the stock air box is long gone. I can try the 48 pilot and a smaller main jet is the cel needle okay or do I need to lean that out also?
    Slidell, LA
    4,738
    I think you are fat across the board. You can try raising the needle clip to the first clip and see if that helps before you start messing with the Jets. Air boxes are a critical feature of an engine. They are essentially wave resonators and are a certain intake track length for the fuel and air mixture. I would recommend finding a set up and putting your air box and intake tract back on.
    Jun 2003
    Cherokee, Oklahoma
    267
    I have messed around with the needle clip no luck ordered new reeds and smaller pilot jet and needle going to try and see if that works. I think you are right its to fat thanks for all the advice Glenn
    House Springs MO
    5,496
    Close up the plug gap to about .018 and run a new plug.
    Jun 2003
    Cherokee, Oklahoma
    267
    I will try that thanks Glenn
    House Springs MO
    5,496
    Quote Originally Posted by bushwacker51 View Post
    Any updates?
    Jun 2003
    Cherokee, Oklahoma
    267
    Sorry been out of town for a week. Ordered some smaller main and pilot jets from ebay and they got lost in the mail. The seller said he is going to reship them also bought new reeds will put them on this weekend I will give an update when the jets come in. Glenn O.
    Jun 2003
    Cherokee, Oklahoma
    267
    Okay I figured it out and I am embarrassed to say what I discovered. I feel like a moron. The motor Had low compression. I pulled the head and discovered that I put the piston in backwards. Screwed up the cylinder and will need a new sleeve. Okay I told on myself. I really dont know how that happened. I know the arrow goes to the exhaust. What the hell guess I am just getting old. Thanks for all the help Glenn O.
    Mexico
    9,018
    Ouch, that sucks. Can you get a sleeve off the shelve, or do you need to get one made?
  15. #30
    House Springs MO
    5,496
    Don't feel bad. I rebuilt my 250r top end years ago and forgot to put coolant in the radiator. It ran for about 20 minutes before I seized it.
