Page 1 of 8 1 2 3 ... LastLast
Results 1 to 15 of 120
Thread: Tri-Z Engines
    Mexico
    9,018
    Tri-Z Engines
    Finally have all the bits to build the engine I’ve always wanted for my Tri Z. Cylinder goes in for a sleeve next week.
    Aug 2005
    CT
    208
    Looking forward to this build!
    Mexico
    9,018
    Quote Originally Posted by floydechoes2000 View Post
    Me too!
    Pulled the studs tonight and confirmed what I’d suspected ever since I found out that YZ pistons are taller than Tri-Z pistons.
    No, it’s not that blonds are more fun than redheads, it’s that the YZ cylinder is a little taller. So for anyone pondering the Tri Z Wrench Report head modification AND a YZ piston l, make sure you check you squish band as you’re decreasing it twice as much with both mods.
    Last edited by El Camexican; 09-19-2019 at 11:25 PM. Reason: Cuz I can’t spell real good
    Slidell, LA
    4,738
    Blinds are way more fun than redheads IMO.....
    Mexico
    9,018
    I really need to stop using this talk to type feature
    Mexico
    9,018
    Aftermarket Exhaust Spring Tabs. 12ga. steel. Contoured to the shape of the cylinder and guaranteed to out last your trike. Available in yellow or silver.
    After they are installed you can bend them to suit any clearance issues or to adjust the tension on your springs.
    I guess you could say that I’m selling them, but I have no idea how I would get them to anybody at this point. They would be cheap though, no more than $8.00 per pair plus shipping. If interested let me know and we’ll figure something out.
    Mar 2013
    Baldwin, Wi
    603
    Welcome to the PV-Z club. I sure could use a couple of those spring tabs.
    85 Tri-z Basket Case
    Mexico
    9,018
    Quote Originally Posted by NeverLift View Post
    Silver or yellow? PM me your phone # again and I'll call you next week.
    Mexico
    9,018
    Took longer than expected to ship it to Kustom Kraft as I wanted to save on shipping by sending 3 cylinders out in one big big, but it’s back now.
    I lucked out and got away with another bore instead of the expected sleeve job.
    Hoping to cleanup the ports over the holidays.
    House Springs MO
    5,494
    Looks good man and the spring tabs are really nice. Having despised Yamaha for most of my life, I feel that I've missed out on owning one of these bikes in running condition.
    Mexico
    9,018
    The one you did have for a short while had a lot of rare parts. Whatever happened to that trike?
    House Springs MO
    5,494
    Got smart and traded it for a 250r.
    Mexico
    9,018
    My three wheel obsession has been reactivated by a future ride, so last night the cases on the soon to be PV engine were opened up.
    Got a chance to use my dowel puller, sure beats Vise Grips.
    I soon came to realize that there was a hack inside this thing.
    Sesame Street song playing.... One of the things does not belong.
    Glad it didn’t ruin the cover, these things are selling for stupid money.
    Then I tried to get the sprocket nut off only to find out someone had put a tiny spot of weld on it to the lock washer. It was almost impossible to see, but the burn hole on the washer was the give away.
    The cherry on the cupcake was finding that they’d welded the shift drum follower wheel solid.
    Seems the bearing on the shift drum (which can’t be replaced) is seized, so off to eBay I went. I hope the shift forks aren’t bent as the guide is bent and the shift shaft was hard to get out.
    Here’s where we’re at now.
    The Open Road
    4,731
    Wow, that escalated quickly
    Sulphur Springs,Texas
    1,005
    Hopefully you’ve found all the hacks an everything else goes smooth for you. Where you able to find a replacement shift drum?
    • 1985 Honda 250SX
    • 1985 Honda 350X
    • 1985 Honda 350X
    • 1986 Honda 250R
    My Feedback Link!
