Results 1 to 9 of 9
Thread: 350x hub differences
    Feb 2013
    Ontario
    812
    Installing some new front wheel bearings in what I believe was a 86 350x front hub. Sprocket side dust seal sits flush with the hub face. My 85 hub seal sits some what below the surface with a bit of a gap which I need to make the front axel sit in all the way in.
    I took them both apart and found the hub on the left with 1.020” front the top of the lip to the inside shoulder where the bearing sits in. The hub on the right 0.820”. Could the hub on the right be a 86/87 200x? I know the 86 200x had the same front wheel as a 86 350x in Canada
    Any info would be helpful. Thank you
    House Springs MO
    5,496
    That hub on the left looks like an early 200x 83-85 hub.
    Feb 2013
    Ontario
    812
    I thought it was to but it’s not. The mounting studs don’t have the nut behind them. Also missing those two small narrow tips on the ends.
    Here’s a pic of a first Gen. 200x hub Click image for larger version.
    Pic of those small narrow taps 85 350x hub Click image for larger version.
    House Springs MO
    5,496
    What is the bolt spacing on that hub? Is it bigger than the one on the right? The right hub looks like a second gen 200x.
    Arizona
    507
    I agree with BKM. The hub on the right looks like 86-87 200x.
    Here is a link to one that sold recently on ebay for reference pictures. It's faster than me going in the garage and digging one out...
    https://www.ebay.com/itm/1986-86-ATC...p2047675.l2557
    Someone needs to make a sticky with pics of the differences in all the hubs.
    Aug 2016
    East of Worcester ma
    1,373
    The hub on the left is definetly an 85 350x.
    85 350x has those little nubs, no other atc has them 99.9% sure.....
    86 no nubs- has those 2 shiny standoffs instead
    The 86/87 200x hub inner collar measurement new(pic) just compare it w/that right hub, if you havent mixed them up (there all different). Well the 85/86 250r and 350x share the same inner collar.
    If its a 86/87 200x hub, yes it'll bolt on but the wheel won't be centered and disc/caliper won't line up in a 350x.
    yes its confusing....
    But ya i agree the right hub looks to be a 86/87 200x hub. And getting harder to find nice ones. This hobby is getting expensive.
    shep
    Feb 2013
    Ontario
    812
    Shep you are correct. I took a pic of both collars. Shorter one is from the 85 350x and the longer one from the 86 200x hub.
    Looking through my hubs and found the correct 86 350x. On the casting it is market out with a 2. And the 86 200x is market with a 1 stamped into it.
ID:	263574Click image for larger version.
    Other then the marking of the number and the shoulder depth. The sprocket is a the only other way to tell. The 86 200x has the studs coming out of them and the 86 350x has bolts that bolt the sprocket into the hub.
    Didn’t think it would be that easy but lots of information I couldn’t find on line or reference.
    May 2012
    va
    6
    Bumping an old thread. I have had these 2 in storage for 20+ yrs., pretty sure the red one is for a 250R, the other I am not so sure about. Is it a 200X? Either way neither do me any good with my 350x.[IMG]img_2712[/IMG][IMG]img_2713[/IMG][IMG]img_2714[/IMG][IMG]img_2715[/IMG][IMG]img_2716[/IMG][IMG]img_2717[/IMG]
