Thread: RD350 on a Tri-z
    May 2008
    Tenn
    548
    RD350 on a Tri-z
    Has anyone ever mounted an RD350
    on a Tri-Z with any success?
    If so, what issues did you face?
    such as the exhaust system and mounts.
    I have seen posts about the 490 but that’s about it.
    Thanks
    Just-Tri-It
    :Trikes Owned:
    1985 Tri-z's 3
    1986 Tri-z
    1984 YTM 200ERN 1
    Oct 2011
    Glamy's place
    98
    I haven't seen an rd350, but this is a banshee engine build:
    http://www.3wheelerworld.com/showthr...ad-A-K-A-Trish
    BVC is building a yz250 based trike with a banshee engine right now.
    https://www.youtube.com/watch?v=FN3StJtUhPU&t=13s
    Neither are Tri-z frames, but you can look at the frame and decide what needs to happen for the tri-z.
    Oceanside, CA
    89
    With a cutoff wheel, a grinder and a mig welder, just about anything is possible.
    I second that and someone to hold your beer while you make the first cut
    Arizona
    843
    BVC Trikes is in the process of building one--see youtube. It involves quite a bit of cutting and welding, e.g., the frame, pipes, etc.
