i remember my KLT, that thing could probably pull a pickup truck in gear up a hill. I wouldve kept it, but the pump was going out and wiring was falling apart. I have the original front fender still.
You will cry, you will scream if you've heard half the **** I've seen.
Are you gonna get up and burn an X in your head?
"Cut throught the bone and cut through the wire"
Trikes:
84&85 Tecates
85 R
85 X
Support Scrapthraher Customs!!! Home of the Three Wheel Outlaws! PM me if you need a head rebuilt, valves cut, head milled or lapped!!!!!
i just bought a 83 klt 200c and its a tank runs great but the plastics are faded to pink!![]()
The first 3 wheeler I ever rode was a KLT200. We rented one and an ATC 200 at Pismo beach in the early 90s. I remember thinking the manual clutch and electric start were much more serious and less toy like than the pull start and auto clutch. They were both a lot of fun to a 13 year old kid, though...
I just got a KLT 200 given to me. The key switch was taken out and directly wired. It was supposedly running a couple of years ago, but I am not entirely sure that it is wired correctly. I can't get any spark and am working on diagnosing the ignitor. I got the coil verified as working. I am wondering if anyone has a wiring diagram that they can email to me or post? I have been looking everywhere, and the Kawi website doesn't show the connections or colors. Can someone please help me out?
my first trike was a klt 200 i think 83 that thing was great on camping trips, i really miss that trike and wish i never got rid of it however when i sold it i used the money toward my 93 cr 125 and didnt miss it as much after riding that bike it was hella fast for a 125 but still miss the klt
Just a quick question, how rare was the speedometer option on the klt250?
Here you go. I hope this will help.
Jason
82 Kawasaki KLT 250
82 Kawaski KLT 200
82 Honda ATC 70
83 Suzuki ALT 125
84 Suzuki ALT 50S
Sky blue Yamaha TriZinger
Yellow Yamaha TriZinger
86 Manco 308
Hello,
I have a 84 KLT 200c... how do you check and lube the rear diff? I have the owners manuel and it says "The differential is not designed for operator service" But this after 26 years I bet it needs some attention.. Its a hell of a lot harder to push in neutral then is my 82' Honda 185s ATC. Also It squeaks a bit when i roll her backwards...
I slid the diff cover to the side and it inside was dry. Does it normal have gear oil?
thanks for the help,
Naz
It's supposed to be checked every 10 days or 100 miles of operation.
Changed once a year.
It takes 2 ozs. of 90 weight gear oil.
Check your PM's for the service data.
You wouldn't still happen to have any of that info still,would you?
Hello I have an 84 KLT 200c that i just bought but it stopped sparking,as well as the starter solenoid going out, the starter will crank if i bypass the posts on the solenoid. Is there anything that someone would recommended to check to try and spark back. I also have a few questions. Does anyone know if the points system from the older klt 200s will fit on the 84 with a cdi? I appreciate points a whole hell of a lot more than i do electronic ignition. Also would the broken solenoid have anything to do with the loss of spark?
ok im getting one of these for free from my buddy. and a yamaha moto 4 but back to the klt. its been siting outside for years .it all looks good but what should i look out for? and yes i already kno i gotta clean the carb and change the oil. so what should i do?
I got a KLT 200a4a Duckster Sunday from dad's neighbor...FREEBIE! It's in good shape but I haven't snapped any pics. yet but I will soon! All camo'd...Haven't been on the site for awhile but I did a google search for the Duckster and found plenty of talk about them on here...The guy asked if I wanted it because he knew I was into trikes and I asked how much...He said to take it because in the spring him and his wife were getting new atv's and this was taking up room...I said no problem and loaded it up...After a $37 battery, runs like a charm!
Rj
Trikes
1981 ATC 250R
1982 ATC 200E
1983 ATC 200E
1977 ATC 90
KLT200A4A Duckster
Bike
1996 CR 500
1980 Z50R
Atv
2003 Prairie 650 (camo)
1998 Big Bear 350
Toys I built
1986 Ford Ranger Prerunner
Sand Rail
