Page 17 of 20 FirstFirst ... 7 15 16 17 18 19 ... LastLast
Results 241 to 255 of 291
Thread: Kxt250 Tecate 3 What Parts Fit Swap Interchange?
  1. #241
    Crest California
    3,014
    I have both bikes... Hmm....
    LED obsessed
    2015 Yamaha FJ-09
  2. #242
    Sep 2005
    MICHIGAN
    2,027
    Quote Originally Posted by Ragar View Post
    I can confirm 1985 Kawasaki KLR250 KLR Front Caliper Fits using the T3 bracket!
    Thank you for taking the time and money to give this a shot. There are probably a lot of calipers out there that will fit but sometimes it takes trial and error.
    86 T3
    84 T3
    86 KX250
  3. #243
    Sep 2005
    MICHIGAN
    2,027
    Cant remember if this was posted
    Dog bone adjustable suspension link for 1986 Kx250 KX500 is same as 86/87 KXT250
    You could even put the dirt bike mud flap on there to be different...lol
    86 T3
    84 T3
    86 KX250
  4. #244
    Ragar is offline At The Back Of The Pack Arm chair racerFirst time rider
    Jan 2015
    Eau Claire WI
    186
    The Case Saver I use.
    I like the look alot. Its not the Cheapest option but it also covers the Sprocket.
    http://www.ebay.com/itm/BLACK-Kawaza.../201290612317?
  5. #245
    Sep 2005
    MICHIGAN
    2,027
    oh so its custom machined by Pentek out of United Kingdom
    I like the plain silver OEM guard piece under the plastic one so I can access the chain and sprocket without disassembly.
    86 T3
    84 T3
    86 KX250
  6. #246
    emmie357's Avatar
    emmie357 is offline At The Back Of The Pack Arm chair racerFirst time rider
    Jul 2013
    Upstate NY
    214
    Quote Originally Posted by nd4speed View Post
    I put an 86 KX250 dog bone on my 85 T3, just needed to use some washers as spacers because the 84/85 dog bones were wider.
    84 YTM200E "yamahauler"
    85 YTM200
    85 KXT250 Tecate
  7. #247
    Sep 2005
    MICHIGAN
    2,027
    Since Kawasaki.com took the tecate info down I have just been using ....UPDATE nothing....everyone is pulling the part numbers and even the links to the different models. Vintage status is here
    86 T3
    84 T3
    86 KX250
  8. #248
    Sep 2005
    MICHIGAN
    2,027
    the 1985 1986 Tecate rear rims are 4/156 bolt pattern 10x8 with 3+5 offset and other atvs that have them are:
    1985 Kawasaki KXT250 Tecate
    1986 Kawasaki KXT250 Tecate
    1987 Kawasaki KXT250 Tecate
    1987 Kawasaki KXF250 Tecate 4
    1987 Kawasaki KSF250 Mojave
    1988 Kawasaki KXF250 Tecate 4
    1988 Kawasaki KSF250 Mojave
    1989 Yamaha YFZ350 Banshee
    1989 Kawasaki KSF250 Mojave
    1990 Kawasaki KSF250 Mojave
    1990 Yamaha YFZ350 Banshee
    1991 Kawasaki KSF250 Mojave
    1992 Kawasaki KSF250 Mojave
    1993 Kawasaki KSF250 Mojave
    1994 Kawasaki KSF250 Mojave
    1995 Kawasaki KEF300 Lakota Utility
    1995 Kawasaki KSF250 Mojave
    1996 Kawasaki KSF250 Mojave
    1996 Polaris Sportsman 500 4x4
    1996 Kawasaki KEF300 Lakota Utility
    1997 Kawasaki KEF300 Lakota Utility
    1997 Kawasaki KSF250 Mojave
    1997 Polaris Xplorer 500 4x4
    1997 Polaris Sportsman 500 4x4
    1998 Kawasaki KSF250 Mojave
    1998 Polaris Sportsman 500 4x4
    1998 Kawasaki KEF300 Lakota Utility
    1998 Polaris Ranger 6x6 500
    1999 Kawasaki KEF300 Lakota Utility
    1999 Polaris Diesel (455cc)
    1999 Polaris Ranger 6x6 500
    1999 Polaris Sportsman 335
    1999 Kawasaki KSF250 Mojave
    1999 Polaris Sportsman 500 4x4
    2000 Kawasaki KSF250 Mojave
    2000 Polaris Sportsman 500 4x4
    2000 Kawasaki KEF300 Lakota Utility
    2000 Polaris Diesel (455cc)
    2000 Polaris Ranger 6x6 500
    2000 Polaris Sportsman 335
    2001 Polaris Ranger 2x4 425
    2001 Polaris Diesel (455cc)
    2001 Polaris Ranger 6x6 500
    2001 Polaris Sportsman 400
    2001 Polaris Ranger 4x4 500
    2001 Kawasaki KSF250 Mojave
    2002 Polaris Magnum 500 4x4
    2002 Polaris Magnum 325 2x4
    2002 Polaris Ranger 2x4 425
    2002 Polaris Magnum 325 4x4
    2002 Polaris Diesel (455cc)
    2002 Polaris Ranger 6x6 500
    2002 Polaris Sportsman 400
    2002 Polaris Ranger 4x4 500
    2002 Kawasaki KSF250 Mojave
    2003 Polaris Predator 500
    2003 Polaris Ranger 6x6 500
    2003 Polaris Sportsman 400
    2003 Polaris Ranger 4x4 500
    2003 Kawasaki KSF250 Mojave
    2003 Polaris Magnum 500 4x4
    2003 Polaris Ranger 2x4 425
    2004 Polaris Sportsman 400
    reference: ITP steel Rims (Part #1025793700, gen. public # 18R156).
    86 T3
    84 T3
    86 KX250
  9. #249
    phantomtracer's Avatar
    phantomtracer is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Pa
    392
    I had a chance to compare an original 86 kx 250 connecting rod against the kxt250 connecting rod kit # 13044-5042
    They are exactly the same part, don't know why the part numbers are different. Kawasaki might have wanted to keep track of what bike or atc was getting the rod so the different part number would help.
  10. #250
    Sep 2005
    MICHIGAN
    2,027
    Boyesen 615 power reeds
    For: Cagiva 250 WMX 1984-1989;
    Cagiva 260 all models;
    Cagiva 500 WMX all models;
    Husqvarna 260 all models, CR250 and WR250 1989-1998, WXC250 and WXE250 1996
    For: Kawasaki KX250 1983-1988,
    KX500 1986-2004,
    Tecate 3 all models,
    Tecate 4 all models;
    Suzuki LT250 1987, LT500 1987, RM250 1981-1986, RM465 and RM500 all models
    86 T3
    84 T3
    86 KX250
  11. #251
    Surprise, AZ
    2,428
    How about a rear shock reservoir line for a Tecate 1985 & 1987?
    That can be bought from a dealer or other.
  12. #252
    Sep 2005
    MICHIGAN
    2,027
    This Kawasaki 39093-1106 PIPE-COMP-SUSP is used on these models and components:
    1986 KXT250-B1 Tecate SHOCK ABSORBER
    Kawasaki 39093-1116 PIPE-COMP-SUSP is used on these models and components:
    1987 KXT250-B2 Tecate SHOCK ABSORBER
    This Kawasaki 39093-1103 PIPE-COMP-SUSP is used on these models and components:
    1984 KXT250-A1 Tecate SHOCK ABSORBER ('85 A2)
    1985 KXT250-A2 Tecate SHOCK ABSORBER ('85 A2)
    I see it listed at $109-122 on one site. I do not think you would want to spend that. It iis a basic hydraulic line and you can have hydraulic lines made all over the nation.
    ebay speedlinez $33
    http://www.ebay.com/sch/i.html?_odkw...linez&_sacat=0
    there is Galfer, call them
    ORI offers these at $150 http://www.ebay.com/itm/NEW-86-Kawas...f196dd&vxp=mtr
    Around Detroit here there are lots of hydraulic shops that make bulk lines. Cheap and easy.
    Or basically any ATV shock line that is the same length.
    86 T3
    84 T3
    86 KX250
  13. #253
    Sep 2005
    MICHIGAN
    2,027
    Differences between tecate 86 and 87 by pics
    http://www.3wheelerworld.com/showthr...and-87-by-pics
    I had put pics about differences between 87 and 86 tecate ,
    The most important differences between 87 and 86 are in bar, pic 1 is 87,pic 2 is 86,87 has keyed ignition,support for head light,different front master brake pic 3,(lever, rubber and hose),different clutch lever and support pic 4(has rear brake),clutch cable is different too has different part number, rubbers in clamps for bar ,Rear brake disc in 87 is bigger that 86(pic 7 and 8),rear brake in 87 has parking brake pic 9,without in 86 pic 10,rubber in chain guard in 87 not in 86 pics 11 and 12,rear brake hose for 87 and 86 different too pics 17,20,reservoir bottle for rear shock in 87 has one wheel in 86 two wheels pics 13 and 14,rear wheels are different too l 87 has the same that tecate 4 and are painted (front wheel is painted too) pics 15 and 16.
    Other pics are labels,different too except warning labels in left side ,warning label in right side is bigger in 87 that 86,87 has in fuel tank one label with gear indicator and other label in front shroud with on off for key switch pic 18,i had tried to charge pics about labels but i cant.
    I hope that you are understand it.
    Javier
    86 T3
    84 T3
    86 KX250
  14. #254
    Sep 2005
    MICHIGAN
    2,027
    The black plastic piece (damper) that holds the tail light on 86/87 T3 is used on many models so my theory is the light that is inside could also be a replacement if the wiring is spliced in.
    This Kawasaki 92075-1782 DAMPER,TAIL LAMP is used on these models and components:
    1986 KXT250-B1 Tecate TAILLIGHT
    1987 KSF250-A1 Mojave 250 TAILLIGHT(S)
    1987 KXF250-A1 Tecate 4 TAILLIGHT(S)
    1987 KXT250-B2 Tecate TAILLIGHT
    1988 KSF250-A2 Mojave 250 TAILLIGHT(S)
    1988 KXF250-A2 Tecate 4 TAILLIGHT(S)
    1989 KSF250-A3 Mojave 250 TAIL LAMP
    1990 KSF250-A4 Mojave 250 TAIL LAMP
    1991 KSF250-A5 Mojave 250 TAIL LAMP
    1992 KSF250-A6 Mojave 250 TAIL LAMP
    1993 KSF250-A7 Mojave 250 TAIL LAMP
    1994 KSF250-A8 Mojave 250 TAILLIGHT(S)
    1995 KEF300-A1 Lakota 300 TAILLIGHT(S)
    1995 KSF250-A9 Mojave 250 TAILLIGHT(S)
    1996 KEF300-A2 Lakota 300 TAILLIGHT(S)
    1996 KSF250-A10 Mojave 250 TAILLIGHT(S)
    1997 KEF300-A3 Lakota 300 TAILLIGHT(S)
    1997 KSF250-A11 Mojave 250 TAILLIGHT(S)
    1997 KVF400-A1 Prairie 400 4X4 TAILLIGHT(S)
    1998 KEF300-A4 Lakota 300 TAILLIGHT(S)
    1998 KSF250-A12 Mojave 250 TAILLIGHT(S)
    1998 KVF400-A2 Prairie 400 4X4 TAILLIGHT(S)
    1998 KVF400-B1 Prairie 400 TAILLIGHT(S)
    1999 KEF300-A5 Lakota 300 TAILLIGHT(S)
    1999 KSF250-A13 Mojave 250 TAILLIGHT(S)
    1999 KVF300-A1 Prairie 300 4X4 TAILLIGHT(S)
    1999 KVF300-B1 Prairie 300 TAILLIGHT(S)
    1999 KVF400-C1 Prairie 400 4X4 TAILLIGHT(S)
    1999 KVF400-D1 Prairie 400 TAILLIGHT(S)
    2000 KEF300-A6 Lakota 300 TAILLIGHT(S)
    2000 KSF250-A14 Mojave 250 TAILLIGHT(S)
    2000 KVF300-A2 Prairie 300 4X4 TAILLIGHT(S)
    2000 KVF300-B2 Prairie 300 TAILLIGHT(S)
    2000 KVF400-C2 Prairie 400 4X4 TAILLIGHT(S)
    2000 KVF400-D2 Prairie 400 TAILLIGHT(S)
    2001 KEF300-B1 Lakota Sport TAILLIGHT(S)
    2001 KSF250-A15 Mojave 250 TAILLIGHT(S)
    2001 KVF300-A3 Prairie 300 4X4 TAILLIGHT(S)
    2001 KVF300-B3 Prairie 300 TAILLIGHT(S)
    2001 KVF400-C3 Prairie 400 4X4 TAILLIGHT(S)
    2001 KVF400-D3 Prairie 400 TAILLIGHT(S)
    2002 KEF300-B2 Lakota Sport TAILLIGHT(S)
    2002 KSF250-A16 Mojave 250 TAILLIGHT(S)
    2002 KVF300-A4 Prairie 300 4X4 TAILLIGHT(S)
    2002 KVF300- Prairie 300 TAILLIGHT(S)
    2002 KVF400-C4 Prairie 400 4X4 TAILLIGHT(S)
    2002 KVF400-D4 Prairie 400 TAILLIGHT(S)
    2003 KEF300-B3 Lakota Sport TAILLIGHT(S)
    2003 KSF250-A17 Mojave 250 TAILLIGHT(S)
    2003 KVF360-A1 Prairie 360 4X4 TAILLIGHT(S)(-JKBVFHA1 3B524150)
    2003 KVF360-A1 Prairie 360 4X4 TAILLIGHT(S)(JKBVFHA1 3B524151-)
    2003 KVF360-B1 Prairie 360 TAILLIGHT(S)(JKBVFHB1 3B503052~)
    2003 KVF360-B1 Prairie 360 TAILLIGHT(S)(~JKBVFHB1 3B503051)
    2003 KVF360-C1 Prairie 360 4X4 Advantage Classic TAILLIGHT(S)(JKBVFHC1 3B503075~)
    2003 KVF360-C1 Prairie 360 4X4 Advantage Classic TAILLIGHT(S)(~JKBVFHC1 3B503074)
    2004 KSF250-A18 KFX 250 Mojave TAILLIGHT(S)
    2004 KVF360-A2 Prairie 360 4X4 TAILLIGHT(S)(JKBVFHA1 3B524151-)
    2004 KVF360-B2 Prairie 360 TAILLIGHT(S)(JKBVFHB1 3B503052~)
    2004 KVF360-C2 Prairie 360 4X4 Hardwoods Green HD TAILLIGHT(S)(JKBVFHC1 3B503075~)
    2005 KVF360-A3 Prairie 360 4X4 TAILLIGHT(S)(JKBVFHA1 3B524151-)
    2005 KVF360-B3 Prairie 360 TAILLIGHT(S)(JKBVFHB1 3B503052~)
    2005 KVF360-C3 Prairie 360 4X4 Hardwoods Green HD TAILLIGHT(S)(JKBVFHC1 3B503075~)
    2006 KVF360A6F Prairie 360 4X4 TAILLIGHT(S)
    2006 KVF360B6F Prairie 360 TAILLIGHT(S)
    2006 KVF360C6F Prairie 360 4X4 Hardwoods Green HD TAILLIGHT(S)
    2007 KVF360A7F Prairie 360 4X4 TAILLIGHT(S)
    2007 KVF360B7F Prairie 360 TAILLIGHT(S)
    2007 KVF360C7F Prairie 360 4X4 Hardwoods Green HD TAILLIGHT(S)
    2008 KVF360A8F Prairie 360 4X4 TAILLIGHT(S)
    2008 KVF360B8F Prairie 360 TAILLIGHT(S)
    2008 KVF360C8F Prairie 360 4X4 Hardwoods Green HD TAILLIGHT(S)
    2009 KVF360A9F Prairie 360 4X4 TAILLIGHT(S)
    2009 KVF360B9F Prairie 360 TAILLIGHT(S)
    2009 KVF360C9F Prairie 360 4X4 Hardwoods Green HD TAILLIGHT(S)
    2010 KVF360AAF Prairie 360 4X4 TAILLIGHT(S)
    2010 KVF360CAF Prairie 360 4X4 Realtree APG HD TAILLIGHT(S)
    2011 KVF360ABF Prairie 360 4X4 TAILLIGHT(S)
    2011 KVF360CBF Prairie 360 4X4 Realtree APG HD TAILLIGHT(S)
    2012 KVF360ACF Prairie 360 4X4 TAILLIGHT(S)
    2013 KVF360ADF Prairie 360 4X4 TAILLIGHT(S)
    86 T3
    84 T3
    86 KX250
  15. #255
    Sep 2005
    MICHIGAN
    2,027
    The 86/87 entire tail light is used on these
    86 T3
    84 T3
    86 KX250
