I was woundering if carlisle strykers are good tires at all? Specifically for my 185s
current ride:
85 350X
I have a set on my YTM225, seem too stiff for a hardtail. I would get something with a more flexible sidewall (your back with thank you). My 185 has Cheng Shin's on the back, they work good.
i run chengchin knobbys on my hardtail and they are very good all around tire
3 wheelaholic
ATC200/CR480 custom
1984 atc250r near mint
wr450f trike on the way
Trizinger for my sons
I would probably use the strykers on a 185 if they were near free or I already had them.. Dont waste the money on a new set.. They are so heavy and stiff its not even funny... even at low psi they will spin on the wheel before the carcass will flex enough to hook.. I bolted a set I had onto my quadracer and it felt like I lost 50hp and was riding a basketball... hills I could pull in 3rd gear before became a 1st gear show.. They look cool(i guess) and might do well in deep mud, but your hard earned money would be better spent on something better...
2-stroke lover
ok, thanks for letting me know. So what would be a good mud/sand tire for my 185s?
Would i have Any luck if i get itp mudlites??
current ride:
85 350X
I had a set on my Big Red which I later put on a 200M. They were ok in dry sand, sucked hard in wet sand, did awesome in mud, and wasnt a bad looking tire(coughcough).
Id bet if they were turned around, they would have done better in the wet/dry sand, but I never got a chance to do that.
84 Honda 200ES Big Red
Do a search for tires, there's a wealth of information on 3ww.
Here's a start
http://www.3wheelerworldforums.com/s...ad.php?t=90146
I have some Duro mud & sand tires(woolly booger copy)on my 185s and they do pretty good.
Turftamers all the way.
If you can't fix it with a, its an electrical problem.
85 ATC 200s--Ratted out and not running at the moment
86 ATC 200x--All stock other than the handle bars
85 ATC 250es Big Red -- Just got new rubbers and she wants to ride!!
04 Suzuki LTZ250 quadsport - It was a decent price and I'm a raging idiot.
