Thread: 200ES Manual Clutch Wrench???
    rebel33382 is offline At The Back Of The Pack Arm chair racerFirst time rider
    New Orleans, LA
    201
    Trying to remove the manual clutch on my big red. It has a funny nut, is there an aftermarket wrench for this nut, I see the the service manual has a honda one listed. Any suggestions?? Ideas??
    Thanks!
    1984 200ES first Shaft driven big red with reverse!
    85 Big Red 250ES with a rebuilt top end!
    Monroe MI
    5,787
    I made one from a 13/16 socket with a die grinder. Do not use a chisel, punch or screwdriver to try and take it off.
    Dec 2005
    Wisconsin
    1,141
    I bought one for the large some of 4 dollars.... Order it and be done, they are cheap.
    YTM-200, Wheeling machine!!!
    1985 Honda 200x...
    ...Just a simple mild 200x
    Sep 2007
    100mi west of Chicago
    3,582
    Hey I made one too when I was working on my 125m. I used my Dremel to make mine.
    Rob
    I tried to make one of the things pictured above, and it failed. I ended up using a and chisel. Not the best way to do it, but it worked.
