what is the proper jeting on this 3 wheeler. mines a 85'. also, i have a cable that is disconected from the motor. when you pull it, it moves a lever on top of the engine. i dont know where this goes, and what it does. could someone please help meh.
i just need to know how many turns it is.
The lever is a decompression device that releases pressure so you don't rip your arm off as it is easier to pull. The lever will stay flipped usually without cable to start, my 185 did anyway. pilot screw setting is 2 turns out from seated position. 2nd groove on needle clip and #105 main jet .......good luck... watch your arm if ya dont use that decompression lever!!
This is from the 84-86 Honda Service Manual.
