Results 1 to 13 of 13
Thread: Rebuilt carb has the drip....
    Oct 2007
    Minneapolis mn
    4,067
    Just rebuilt the carb on my BR, now I seem to have a overflow drip... Any input? I pulled the float back out, blew out the seat with compressed air... Is there a way to do any adjustment to the float? Or do I just start looking for a new one?
    Apr 2009
    Saskatchewan
    119
    As far as I know there isn't any float adjustment. I got a new one on ebay for around $70 seems to work just fine.
    Feb 2008
    Orange County California
    726
    It is most probable that there is a adjustment to the float, I have never seen any kind of a carburetor that did not require and adjustment, but I can not tell you what it is for your carb, Sorry.
    However what I can tell you is to eyeball the float travel, bend the tab that the float has attached to it, near it's point of articulation, and prevent the float from traveling higher than what would seem normal to you. Then reassembel and check. You may have to this several times, but you will get close.
    Hopefully someone here can help you better than my moronic way of doing it, but all I can say, is YES, there should be some sort of an adjustment.
    1986 ATC250r
    1984 ATC70
    Feb 2009
    michigan
    2,387
    drippy
    did it drip before you touched it.did you work on the carb with the floats still on.maybe you bent the float support and changed the float level.just bend it back if thats the problem.easy.or maybe needs a shot of penicillian ha ha ha
    1985 ATC 250R
    . Team Red Trike
    Oct 2007
    Minneapolis mn
    4,067
    The carb was a total p.o.s. when I got it... There was so much rtv instead of a bowl gasket, it held the floats up... The guy I bought it from wasnt too bright to say the least. Cant bend the tab, its plastic...
    So I am sitting here, having a beer, when VIOLA! Genius strikes... My BR just needed a beer to fix the float! I polished off my beer, cracked open another one, grabber a scissor (sp?) and cut the can open. Cut little tiny shim pieces, and shimmed the float up till it was level and applying the correct pressure on the float valve! No need to spend big money, just needed a little thinking juice!
    Oct 2007
    Minneapolis mn
    4,067
    Fixed my float with a beer!
    The float was getting a bit worn in my BR. Really should be replaced, but no money, and I wanna go riding on saturday... Getting really tired of the drip out the overflow too... So I am pondering what to do, sit down and look at the carb for a few moments while I enjoy a beer, when all of a sudden, BEER is the answer! I cut up a few pieces of tin from the can, and used them to shim the float valve! And to think, my wife says I never come up with good ideas when I am drinking... This will show her!
    Southern MN
    1,875
    Haha, thats hilarious. Where do you usually ride? Have you evere ridden the course near fairbult? cool to see all these mn riders coming up. We should try to set up a ride session sometime in the near future.
    81, 85 Yamaha Tri Moto 125
    83 Yamaha Tri Moto 200 x2
    85 Yamaha Tri Z 250
    84 Kawasaki Tecate 250
    84 Honda ATC 70
    85 Honda ATC 350X
    84 Honda ATC 250R
    (2) 84 Honda ATC 200x
    82, 83 Honda ATC 185s
    81 ATC 200
    Lots of other parts and bikes
    Monroe MI
    5,787
    Oct 2007
    Minneapolis mn
    4,067
    I hear it too... What can we say, great minds think alike, and so do ours...
    It was 2 differnt posts, that the mods put into one...
    Quote Originally Posted by Thorpe View Post
    try to refrain from doing that in the future..one post will keep the site cleaner, thank you
    Sep 2007
    100mi west of Chicago
    3,582
    Haha it makes it look like you got drunk and posted pretty much the same thing an hour later in the same thread.
    Rob
    Oct 2007
    Minneapolis mn
    4,067
    Only had 2 beers... 1 to use as shim material, and 1 while doing the shimming...
    Maybe I am just a
    Feb 2008
    726
    That is funny as all hell, creative minds at their best LOL!
    1986 ATC250r
    1984 ATC70
