Results 1 to 7 of 7
Thread: Restoring Metal Gas Tank?
    Apr 2009
    New Hampshire
    46
    I am trying to restore a gas tank for my 83 250r. The inside of the tank has some rust. It doesn't have any holes or anything and doesn't leak at all but i was wondering if you guy know of anything to fix this? I have hear a while back that they is something you can put in the tank that creates a permanent coating inside??? Any help would be great! Thanks,
    -Chris
    If it ain't broke, fix it 'till it is!
    1987 250sx
    1983 250R (project)
    Apr 2009
    New Hampshire
    46
    OK...i guess i answered my own question. I found this http://kbs-coatings.amazonwebstore.c...B000IBDIX2.htm
    Have any of you used this before? How well does it work? $35 for this of about $70-$100 for a "new" tank on ebay
    1987 250sx
    1983 250R (project)
    use the SEARCH for gastank coatings,red kote has been talked about many times
    Feb 2009
    michigan
    2,387
    new tank
    if you coat, get rid of rust first.pour in some bb's with a bottle of navel jelly and shake,shake,shake.in a lttle while there will be no more rust.may not even have to coat.
    1985 ATC 250R
    . Team Red Trike
    Jul 2006
    screw naval jelly, I go straight to the killer... go buy some muratic acid... pour a few quarts in slosh around for a few mins and pour out preferly on small children, cats and dogs. then stick a water hose in it for a few mines to wash it all out, try to get most of the water out either sit out in the hot sun or use a blow dryer to dry it completly out... then the inside will be rust free again.
    Feb 2009
    michigan
    2,387
    go big
    go right to the nuclear method,i like it
    1985 ATC 250R
    . Team Red Trike
    Monroe MI
    5,787
    Damn, I just blasted coffee out my nose reading this...
