Results 61 to 75 of 87
Thread: Broken Fenders
  1. #61
    Jun 2009
    iowa
    32
    Thanks i'll keep that in mind.
  2. #62
    shadix518's Avatar
    shadix518 is offline At The Back Of The Pack Arm chair racerFirst time rider
    May 2009
    Wichita, Kansas
    198
    i dont think the 200x will fit without alot of modification....
    1985 Atc 250sx my first.....
    1985 Tri-Moto 200......SOLD
    1985 Yamaha 225dx.....
  3. #63
    Jun 2009
    iowa
    32
    I dont think Dirt bike forks are big enough to hold a three wheeler tire.
    Does anyone have a suspension that would work on my atc90?
  4. #64
    Monroe MI
    5,787
    Nice little bike. Doesn't seem like it needs much. I can see why you want fenders though.
  5. #65
    May 2009
    Brampton, ontario
    686
    no dirt bike forks wont work, but with a chop saw and welder you can use your current forks and just weld the shocks on.
  6. #66
    1984ATC200S's Avatar
    1984ATC200S is offline At The Back Of The Pack Arm chair racerFirst time rider
    May 2008
    New Brunswick Canada
    222
    im no expert on the 90's but i pretty sure a 200S front end will bolt on with no mods except the steering stops, correct me if im wrong, but Ive positiver Ive seen them one here like that. http://www.3wheelerworldforums.com/s...&highlight=GPX
    1984 200s
    1984 big red
    1980 Kawasaki Invader 340 liquid
    1993 GMC sierra, 4.3L automatic
    1990 Chev Scottsdale -parts
    1989 Chev wrangler 4.3L 5 speed- parts
    Chevs are for parts GMC's are for driving
  7. #67
    Feb 2009
    michigan
    2,387
    fork swap
    185s or 200s forks are direct swaps for that machine
    1985 ATC 250R
    . Team Red Trike
  8. #68
    Jun 2009
    iowa
    32
    When i get my plastic fenders i was thinking about painting them a different color.
    Would that work very well , is their a special process to make the paint hold better?
    Also i found a 200x front end suspension would that work on my honda atc 90?
  9. #69
    Jun 2009
    iowa
    32
    I just found out that the guy already sold his fenders so i'm back to think about fiber glass.Would it work if i encased my whole fender in fiber glass.
  10. #70
    shadix518's Avatar
    May 2009
    Wichita, Kansas
    198
    i would just just make new ones all together and the 200x front end wont fit your bike you need the 185s or 200s front forks if you want suspension. below is the process i would do.
    The process i would take is you can take some aluminum foil to lay on your old fenders...the reason for this is it will make it to where you can easily remove the fiberglass once it is fully dry with out it or some bee's wax it will be very hard to remove the fiberglass from the plastic without damaging it. the mixture for the hardener and resin will ither make or break this project to much and it will dry to fast and be very brittle to little and it will take forever for it to dry so make sure you get the right mix. and you can do what lukeatc said and get some of that rubber lining to put on the edges after you sand prime and paint it...good luck
  11. #71
    Dec 2002
    deer park, texas
    2,336
    do not fiberglass them fenders. i think someone on here can locate you a set pretty cheap. By the time you spend the money for material you are alsmost to the price of a used set.
    As much as i do not like the way Fabiodriven stated his opinion earlier. I must agree with him. please take your time. Used the zip tied fenders until you get something nicer. the zip tied fenders will look a hella lot better than what you are going to recreate. If you had nothing it would have been fine.
    Never argue with an idiot. They will bring you down to their level and beat you with experience.
    Calling an illegal alien an undocumented immigrant is the same as calling a drug dealer an unlicensed pharmacist.
    1981 Wife ( Project)
  12. #72
    shadix518's Avatar
    May 2009
    Wichita, Kansas
    198
    heres a set of front and back for a decent price.
    http://cgi.ebay.com/ebaymotors/Honda...5%7C240%3A1318
  13. #73
    Dec 2002
    deer park, texas
    2,336
    that is a good price.
  14. #74
    shadix518's Avatar
    May 2009
    Wichita, Kansas
    198
    yea i wish i could find a set for my 250sx at that price
  15. #75
    Jun 2009
    iowa
    32
    That is a good price.I have always had an interest in fiber glassing so i think i will still try it and if it dont turn out i will buy some.I'm going to do the front fender first since its smaller. How thick should it be or how many layers of fiber glass should
    their be?
