alright guys heres my problem i went to tighten my chain and the carrier is seized or somthing please help i took the two bolts completley out i have not clue what to do it wont move either way
Your best bet is to break the rearend apart and grease everything. You might even have to knock it apart with a rubber. I usually pull the carrier out and clean it and the swingarm and then grease it upon reassembly.
Trikes: Cagiva 200, 85? Tiger 250,(2)84 200x's , (3)86 200x's, 87 200x, (5)85 350x's, (2)86 350x's, (2)85 250r's, 86 Tecate, (3) 85 250sx's Restoring: 83 200x, 86 250sx. Too many utility trikes to list.
I hate to steal somebody else's quote but what the hell- If you can't figure out how to adjust your chain you probly shouldn't own a three wheeler. I mean, it is tough. I'll give you that. Just think though- once you conquer chain adjusting, you can move on to bigger and better things like clutch adjusting, and maybe, just MAYBE, someday you will bleed a brake. God bless America!![]()
From the manual
Never argue with an idiot. They will bring you down to their level and beat you with experience.
Calling an illegal alien an undocumented immigrant is the same as calling a drug dealer an unlicensed pharmacist.
1981 Wife ( Project)
also it says, were the manual scan cuts of to buy a new chain
alright first of all im not stupid and second it has a brandnew chain the only way it tightens up is if the rear brake caliper is off then it will tighten and loosen
is the caliper stay suppose to be tight on the bearing carrier??? cause every time i move that the bearing carrier moves is it rusted ??
where at in Oregon are you ? ? ?
i live in gresham oregon why you ask???
If the caliper mount doesn't spin on the carrier, how can the carrier pivot to adjust the chain??
Sounds like you've got something seized up somewhere.
Also, take the 2 carrier pinch bolts out and screw them in from the bottom. Put something flat, like a large washer in the pinch bolt gap and tighten the bolts against it. You'll see the swingarm seperate just a bit.... It helps open it a bit more and you can spray some crap in there too.
Hmmm - I wonder who said that about adjusting the chain![]()
i fixed it the caliper mount was rusted to the carrier thanks to the people that actually tryed to help
Good you got it Fix, Now Let's see some Pictures ?
