Results 16 to 30 of 34
Thread: will it hurt the fork shocks to..
    Southern MN
    1,875
    If the rear shock is bouncey, it needs rebuilt or replaced, tighting the spring wont help at all. Take the fork cap all the way off. You can probly use a crescent wrench if you dont have the right socket or wrench to fit it. I would first drain the oil from the bottom of the fork, then add the fresh oil in the top. If it leaks as bad as you said it does, it will likely leak out pretty fast, and the suspension action wont work like it was intended to.
    81, 85 Yamaha Tri Moto 125
    83 Yamaha Tri Moto 200 x2
    85 Yamaha Tri Z 250
    84 Kawasaki Tecate 250
    84 Honda ATC 70
    85 Honda ATC 350X
    84 Honda ATC 250R
    (2) 84 Honda ATC 200x
    82, 83 Honda ATC 185s
    81 ATC 200
    Lots of other parts and bikes
    Jan 2011
    Avon, Minnesota
    641
    yea its squeaky and squishy. i mean when i sit on this trike it almost bottoms out. (im 180lbs) i doubt the rear will ever get rebuilt in my future unless it blows or something. it comes up all the way in the back with no weight on it. and the front shock is wierd sometimes it will leak really bad and sometimes not much. but thats problay cause there is little to no oil in it. and that 10mm screw on the bottom is the drain right??
    1983 honda 200x 185 motor, Uni air filter, bassani exhaust, itp rims. FOR SALE!!!
    1982 honda 200 bigred cobra exhaust
    1989 yamaha banshee fmf gold pipes boost bottle k&n airfilter
    Southern MN
    1,875
    ^ That is a very good write up. Never seen that one bofore. I also use a piece of pvc as a seal driver, and never had a problem. Thanks for putting that up Travi.
    85 Yamaha Tri Z 250
    84 Honda ATC 70
    85 Honda ATC 350X
    84 Honda ATC 250R
    81 ATC 200
    Jan 2011
    Avon, Minnesota
    641
    o dang travi i didnt see your post thanks abunch for that thread
    Oct 2011
    lower sackville , Nova Scotia
    35
    no problem , it was my first time rebuilding forks and i followed that guide it was very simple , and my forks were filled with mud lol.
    Jan 2011
    Avon, Minnesota
    641
    my leaking fluid looks like yours lol. so i will problay put some atf in for the rest of the winter then rebuild them after it gets warm. since my garage is not heated and cold wrenches+damp hands= alot of pain. Im going to favorite that thread and use it for refference thanks agian everyone
    Oct 2011
    35
    no problem , when you rebuild them it wont even feel like the same bike .
    Jan 2011
    Avon, Minnesota
    641
    i wish it seemed so easy for the rear shock also
    Oct 2011
    35
    Quote Originally Posted by yamaha driver View Post
    that is not me or my write up BTW i take no credit for it
    Jan 2011
    Avon, Minnesota
    641
    ordered a pair of parts unlimited fork seals today from dennis kirk for 6.95 . will start the rebuild this fridayD
    Oct 2011
    35
    if your seals have been bad for a long time i also recommend some cleaner , i use brake cleaner , as there is probably water and all sorts of unknown things in there .
    Las Vegas, NV.
    2,520
    If you want your new fork seals to last, you really should install some new bushings as well. I can almost guarantee that they'll be worn out, which allows excessice play in the forks. If you only put in new seals, the excessive play will wear out your new seals in nothing flat, then you'll have to pop for new seals again, along with the bushings. When you open up the forks, if the bushings are bad, do yourself & your wallet a favor by doing the job right, and install some new bushings. I realize you want to get back to riding ASAP, and don't want to have to wait for additional parts, but having to do the job twice, to do it correctly, is a waste of time that could have been prevented.
    Jan 2011
    Avon, Minnesota
    641
    Where would I be able to buy these bearings
    Las Vegas, NV.
    2,520
    Here's another thread on the same subject, that contains some answers. http://www.3wheelerworld.com/showthr...-fork-bushings
  15. #30
    Jan 2011
    Avon, Minnesota
    641
    How do I tell if they are junko
