Results 16 to 30 of 41
Thread: Works ultracross shock has arrived pics pics pics
    Jun 2004
    Oregon
    1,781
    Dang with a +4 swinger it wont fit in my truck anymore haha
    1986 ATC 250R
    Ported w/ Cool head
    LED pipe and silencer.
    Vforce3
    Keihin PWK 38mm
    Works Ultra Cross Shock
    LSR +2 Axle
    American Star Racing +4 Swinger
    LED Intake
    Hi-Flite desert seat
    OEM clutch 89 upgrade
    2021 YFZ450Rse Rossier R5 Titanium Header AIS Delete FCI Vortex ECU
    Sure it will, just let the tailgate down
    9,014
    Quote Originally Posted by Fox250R View Post
    God I hope so! I can't wait!
    I have a bottom of the line Works shock on my Tri-Z. It has no damping or rebound, but it was custom made after I answered a bunch of questions over the phone. The only thing I had to do out of the box was crank up the pre-load a couple turns and it seems to have the proper amount of sag. It floats over everything I’ve ridden it over and it’s never bottomed out (keep in mind that at my age fear of flight has set it).
    I rebuilt the front and put in a set of progressive springs. It too seems perfect for my style of riding. By the time I had the front end together I’ll spent about $500 ($200 was wasted on POS ebay sellers) and was regretting not going with inverts, but after riding it I’d have a hard time justifying the upgrade. Trust me, you be thrilled when it’s all together.
    What makes you think your tubes are beyond repair? As long as they’re straight and not pitted or dinged you should be able to get them in A1 shape for under $250.
    Jun 2004
    Oregon
    1,781
    I hope you're right.. I'm a bit more nervous about the forks then anything else I'm about to do to it hahah!
    1986 ATC 250R
    Ported w/ Cool head
    Vforce3
    Keihin PWK 38mm
    LSR +2 Axle
    LED Intake
    82 250r's Avatar
    82 250r is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Mar 2007
    Utah
    278
    Are you replacing seals on the front forks?
    It's not that bad even if you've never done it before.
    I have a nice seal installer if you need to borrow it...that will save you a few bucks.
    Take your time and smooth out any dings with 1000 grit sand paper & polish the forks.
    It'll kick azz when you're done!
    STL
    3,560
    i missed this somehow, that shock is awesome man! I'm jealous! And its time for a bigger truck lol. My 86 R with plus 6 swinger fit just barely with the gait up on my 2003 F150. I'm interested to see how it looks completed, the black swinger and black spring on the Works shock should look sharp together
    Jun 2004
    Oregon
    1,781
    Quote Originally Posted by JasonB View Post
    Thanks man, Its a bit overkill I'm sure but hopefully ill love it
    1986 ATC 250R
    Ported w/ Cool head
    Vforce3
    Keihin PWK 38mm
    LSR +2 Axle
    LED Intake
    Jun 2004
    Oregon
    1,781
    Quote Originally Posted by 82 250r View Post
    As far as I know, I'm tearing both forks down and inspecting the tubes.. If all is ok (and I don't believe it will be) I will be replacing all seals and springs.
    If it comes down to it i'll have them professionally done.
    I replaced the seals like 3 years ago and they both started leaking oil like a month later and I never bothered to mess with it.
    1986 ATC 250R
    Ported w/ Cool head
    Vforce3
    Keihin PWK 38mm
    LSR +2 Axle
    LED Intake
    Oct 2013
    Wherever I May Roam
    3,757
    Forks are super easy if you have a seal driver (purchased or made), a good pair of snap ring pliers and a service manual handy. Don't forget to replace the slider bushings if the Teflon is worn. If you've never replaced them I would do it anyway.
    Jun 2004
    Oregon
    1,781
    I will keep that in mind! Thank you
    1986 ATC 250R
    Ported w/ Cool head
    Vforce3
    Keihin PWK 38mm
    LSR +2 Axle
    LED Intake
    STL
    3,560
    Those shocks really are awesome, my buddy Gary Crum picked up Dham's (David Hams) built up 250r with a works shock on it and that thing just soaks up woops and bumps. Suspension upgrades are where its at! I had my stock shock redone and added rebuilt inverted forks to one of my 250r based bikes and the difference is amazing. Nothing compares to riding a bike with worn out forks/shock and jumping over to a fresh set up
    Jun 2004
    Oregon
    1,781
    Your forks look amazing! Did you pull them off another bike?
    1986 ATC 250R
    Ported w/ Cool head
    Vforce3
    Keihin PWK 38mm
    LSR +2 Axle
    LED Intake
    STL
    3,560
    this set is actually one of Jason Hall's. He has the Triples machined and uses CR125 forks that he has shortenned about 3 inches and rebuilt. I have a second set that are supposed be shipping to me this week for my 310R bike. Theres a new guy tossing his hat in the ring for producing inverted trike fork set ups this summer that I am looking to have make a set for my 350X. After riding the 500 with these new forks on it i wont go back to conventional cartridge forks. just feels different! I like that they are firm and actually support the beating i gave em so far lol. Plus they look bad ass!
    Jun 2004
    Oregon
    1,781
    What did those set you back if you don't mind me asking?
    1986 ATC 250R
    Ported w/ Cool head
    Vforce3
    Keihin PWK 38mm
    LSR +2 Axle
    LED Intake
  15. #30
    STL
    3,560
    lol. it hurts to say. hmmmmm
    cr125 forks on ebay ~120 per pair shipped
    pivot works rebuild kit 60$?
    cr125 brakes complete with master line rotor and caliper `120$ shipped
    triples and kit was around 600
    fork rebuild and shortening by Hall was another 300
    fork gaurds 30$
    brake line clamp 30
    pricey to say the least. i mean i have no freaking clue why i have two of them let alone shopping for a third
