Results 1 to 10 of 10
Thread: Here's why periodic maintainance is improtant.......
    Scootertrash's Avatar
    In the sticks
    4,638
    Backstory: I got this 85 250ES last fall to use for dimensions and test fitting of one of my ski kits. The front axle was rusted into the hub solid. I was able to get the wheel off of the machine, but getting the hub off of the axle was a bear. I ended up with one inner bearing race and the collar/bearing spacer locked onto the axle tighter that a nuns..... Well, the wife was restructured out of her job, so my focus switched to making up the difference in income by working my gonads off till she can find something else. The axle has been in the freezer since about December :I So I got a little break this weekend and focused on some projects that had been collecting dust and grabbed the axle out of the freezer. Here's what transpired.....
    This axle had never been off this machine since new.
    I mounted the front axle in the vise and used a 4 inch grinder to cut 2 grooves into the collar approx 180 degrees apart
    I then clamped the axle vertically in the vise and drove a chisel into the slots I cut to break the collar halves free of the axle
Name:	250ES axle2.jpg
    One half came of fairly easily, the other half need a little more persuasion
Name:	250ES axle3.jpg
    I used a dremel to cut a little deeper on the bearing race, then used a chisel to split the race. Interestingly, the axle spacer just required heating and broke loose nicely, so I was able to salvage the spacer along with the axle.
Name:	250ES axle4.jpg
    NEPA
    7,051
    GREAT post ...I never took this kind of time to see what I was up against!! Just replaced w used...Great post.
    Dec 2002
    salem, nh
    1,339
    wow. good job, looks like the axle is still salvageable.
    85 250SX New to me!!
    85 ATC 70 stock ~ TRADED
    85 ATC 70 with 138cc Lifan
    83 110 restored ~ sold
    85 110 restored ~ sold
    83 200x restored ~ sold
    02 400ex ~~~SOLD
    K&N filter
    K&N jet kit
    EHS Racing lid
    Removed choke 42 pilot DJ146 main
    HMF full exhaust
    AC skids
    Holeshot XCR rears
    14t front sprocket
    IMS Roll front bumper
    Graydon Proline nerfs
    Oct 2013
    Wherever I May Roam
    3,757
    That's wtf I'm talkin bout scooter
    Now that there, is a real mechanic.
    In the sticks
    4,638
    Quote Originally Posted by kilabeez0 View Post
    Coupla minor scrapes to the axle with the grinder but nothing that will compromise the structural integrity of the aforementioned axle.
    Oct 2013
    Wherever I May Roam
    3,757
    When I built this bike Click image for larger version.
ID:	195480 the rear mechanical disk was fused to the rear axle. I ended up having to cut the disc from the hub, then split the collar it left behind. The two halves still did not release until I made a couple relief cuts.
    Had to dig these outta the scrap pile and take a pic to let ya know you're not alone
Name:	dx brake mess.jpg
    This was the result
    Apr 2004
    Brigham, Québec, Canada
    1,529
    Never-seize is your best friend!
    1984 Yamaha YTM-225DX
    Québec 3-wheeler riders group
    In the sticks
    4,638
    This was the result
    It's nice to see others who won't be defeated by the results of crappy maintenance by others. I had to try, but you already know what I mean.
    In the sticks
    4,638
    Quote Originally Posted by Yamada View Post
    Any lubricant will degrade over time. I don't think never seize would hold out much better without being refreshed a time or two over almost thirty years. If you read my OP it says the axle had never been off the machine since new.
    Nov 2013
    Oxford CT, New Haven County
    984
    Nice... and I cant keep my Break Disc still, damn thing sounds like bells are coming out of my butt when I ride!!
    Hey, at least you didn't almost smash a finger beyond hope trying to get your rear shock off....lol driving out that Pin was like something I had never experienced before, usually you give it a good whack and they slide out, I think this one was welded in! lol
