Results 1 to 15 of 19
Thread: check out these gnarly tires
    Jun 2014
    madison
    102
    I bought these gnarly tires to upgrade the rear tires on my 110 honda. These are called the OTR 38 Special. They look pretty gnarly to me and I think they will provide adequate traction for my needs without bogging down the 110cc engine. They are super thick tires and have a flat profile which means a larger contact patch with the ground. I think they are 6 ply tires. I had these mounted on AMS steel wheels with tubes. $300 for the pair but I think well worth the money. I will post an update soon on their performance. Click image for larger version.
ID:	197265Click image for larger version.
ID:	197266Click image for larger version.
    Jun 2014
    St. Louis mo.
    30
    Those look like some awesome meats there. Bet they will get you in a hole and then dig it a little bit deeper to lol
    9,018
    Not a Honda guy, but I'm guessing you have a solid axle. Do those tires have any side wall flex?
    Jul 2014
    plaquemine, louisiana
    12
    sweet! looks like they should last a while
    Jun 2014
    Gainesville, FL
    45
    6-ply on a rigid bike.....better get yourself a kidney belt!
    '84 Honda ATC200ES Big Red - Tagged & Street Legal!
    Apr 2012
    USA
    4,129
    Looks almost like the tire I bought for my 84 200es big red except it don't have the extra wide groove in the middle. I only paid $30ea for mine (below store cost at TSC). I guess it was an old model being replaced or something. They are 25x13x9 and I think their original design were for the gator or something like that (road + off road). Photos below are of mine after ~5 years of use, basically new yet lol.
ID:	197276   Click image for larger version.
    Cold Lake, Alberta, Canada
    3,019
    They look great, but they look heavy and will ride like a rock even without air in them I'm thinking. Tough to beat soft knobbies on a rigid frame for a smooth ride with reasonable traction.
    Trikes
    1970/71 US 90 (Aquarius Blue)
    1972/73 US 90 Green
    1982 ATC 70
    1983 ATC 70 (Ladybug)
    1973 ATC 70
    TF 2015
    Other
    1983 Honda Z50
    Apr 2012
    USA
    4,129
    Agreed, my big red had the oem tires before, but were dry rotted really bad. I ride in sand though, so it wasn't a huge issue. They work as good or better in the Michigan mud and can handle quite a load (trailer in my case).
    Jun 2014
    madison
    102
    I prefer wide tires for stability reasons. Balloon tires are too tippy for me. I hate those cheng shin dimpled knobby tires or any balloon tire that is thin and thorns would easily puncture. my friend's cheng shin had about a dozen plugs in it before it was eventually unrepairable. stay away from 2 ply rated tires. they pop easily.
    Mar 2013
    Central PA
    2,362
    Quote Originally Posted by wamulass View Post
    I will gladly take all your oem style 2-ply knobbies. Nothing beats them on a hardtail. Eventually people realize that.
    Jun 2014
    St. Louis mo.
    30
    Tubes are cheaper than tires by far and I run tubes in all my atc tires just for this reason. Yes it does get really old running a sharp rock or stick into a 2 ply and I'm one of those trail blazing types that likes to go off the beaten path. I mean if your into power slides and high speed cornering then yes wrong choice of tire but if your climbing some crazy stuff or in some soft ground the softer tire is a bonus to help float over it until your ready to rev it up and dump the clutch and turn them into trench diggers lol
    Jun 2014
    madison
    102
    i have no more 2 ply tires. my front tire is a nanco bushwhacker 22x11-8 (trail pro copy) i know how hated the tire is on this board but it performs fine for my purposes. It never goes flat either and i only run 5 psi in it. its rated as a 4 ply but built like a 6 ply. and yes it has a tube in it as well due to the split rim.
    I am a casual rider and don't do power slides. I do off road a lot and when I do i run 2 psi per tire in all three. and these are the 6 ply tires.
    Feb 2013
    Brazil, Indiana
    728
    I was given a set of them Calise Field trax tires off of a gator. Someone had put a new set rear tires on the front of one and when the gator came back from overseas ( I work in a military maintenace shop) they ordered the right set and didnt have use for them. Since they were 22x11x8 I snatched them up and put them on my 79 110. They are a bit more rough but for free I'm not gonna complain.
    1979 ATC110
    1983 ATC110
    1984 ATC110
    1984 ATC125M
    1985 ATC110 2 of them
    1985 ATC110 The wife's
    1987 ATC125M
    1985 ATC250ES
    1984 DX225 with 250 timberwolf engine and swingarm. Wolf in DX clothing
    2,591
    If they are 6 ply tires, they will bog the engine down a little since they are heavier than the stock tires. A 110 isn't exactly a fire breathing power house although they are good little trikes.
    Jun 2014
    madison
    102
    I have had them on for two days now. Acceleration is tad slower and I do notice a small reduction in top speed, but I am not trying to race my 110. I use it to get around my parent's farm and to tow a small garden cart. So far, so good. No wear, even after a day on a paved driveway and gravel hills. And best of all, those AMS steel wheels are one piece so no leaks, even though I have tubes in them anyway. Only complaint is they run a little small; about 20.5" tall and 11" wide so ground clearance is a little less. I{f they outlast the trike, I am happy.
