Results 1 to 4 of 4
Thread: help me on my YTM 175
    Apr 2015
    france
    6
    hi guys i have problems on my YTM 175
    i dont know how to plug the carburetor, there is a little pipe on the bottom of my carburetor i dont know where it go. i think its to put pressure into the carburetor but i dont know.
    my 3wheeler start when i drop gaz into the sparks chamber then it stop. i cleaned all the carburetor but i dont know what to do
ID:	215490   Click image for larger version.
    Dec 2014
    Redmond, Oregon
    38
    The little brass pipe on the bottom of the carburetor is the bowl overflow tube. Its supposed to have a tube attached to it to drain fuel underneath the bike if the carburetor bowl gets over filled. The two black plastic fittings on either side if the carb are the carburetor vents. Make sure they are not plugged. The round knob (about 1cm in diameter) on the choke side of the carb is the idle speed adjuster screw, also known as the slide stop. The small brass screw near the intake opening of the carb is the idle air mixture screw. There is another small nipple on the other side of the carb near the outlet side, and that is where the oil injection line is supposed to go.
    Here is a link to the factory manual for your trike: http://www.oscarmayer.net/atc/manuals/
    It should give you a good starting point for the idle speed screw, and the idle air mixture screw.
    Apr 2015
    france
    6
    Quote Originally Posted by dgm635csi View Post
    okc thx
    do you know how to make sure the carb is working good ? because i can only start it then it stop
    Apr 2015
    france
    6
    ok thanks for help
    do you know how to make sure the carb work properly ?
    because i can start my moto if i drop gaz into the carb then it stop!
