Results 1 to 10 of 10
Thread: Add Left master cylinder to Auto-X
    RUNMEDOWN is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Jun 2006
    Omaha Nebraska
    321
    Cant seem to find the info I am looking for, I am building an Auto-x and am thinking that I would rather not deal with the right-foot brake mod (I don't use the foot brake on my other Trikes) and just put a master cylinder on the left hand in place of the (No longer needed) Clutch lever and get a custom braided brake line to run to the back caliper. Any reason not to do this?
    85 ATC110 - The Greatest ATC of all time - (My First - new in 85)
    83 FL250 - Odyssey w/420cc - SOLD
    82 185s -10.25:1 piston, Full 200x upper, Goki Electric start - SOLD
    84 200x - Auto-X - Weisco Hi-comp, Cam'd, Bassani'd, Westcoast swinger, -SOLD
    82 200E Big Red -SOLD
    85 ATC250ES Big Red - Snow Plow !
    Miami,Fla.(305)
    808
    I really dont see a down side on your auto-x... Thats exactly what I did a couple yrs ago but on my ATC 185S (converted to rear disc brake). Anyway, I used a left-hand master cyl. simply because it was gonna be tricky (for me) to make the stock 185S foot brakepedal work with a rear master cyl.-
    I would definatly use a lefthand master cyl. vs. a righthand master cyl. You dont want throttle & brake using the same hand obviously. That being said-
    Whats YOUR reason for doing this though????What right-footbrake mod are you talking about???? A 200X is already set up for disc brake-im confused...?
    Previously Owned:
    1985 ATC 250R (261cc)- 38MM PWK QV/AS, VFORCE3, RPM TIMING ADV., FULL DG EXH, CLARKE WHITE TANK, DOUGLAS RED LABELS, PRM NERF BARS, + ALUM. PARTS
    1983 ATC 185S (186cc)- HI COMP., BASSANI HEADER, REAR DISC BRAKE CONV., '86 200X HUBS, ALUM. RIMS, DIRT DEVILS
    1982 ATC 185S (224cc)- PK WELD-ON KIT, PK CLAMPS, PK EXHAUST, SL90 SHOCKS, OIL COOLER, PCCC RIMS
    1981 ATC 185S
    1984 ATC 250R
    1981 ATC 250R
    1983 ATC 110
    1969 HONDA MINI TRAIL 50
    TRIKELESS
    N/A
    5,818
    PM me if you want to buy a new mastercylinder. I sell them left and right side.
    Miami,Fla.(305)
    808
    After thinking about it-I assume the stock brake pedal needs to be removed to fit 185/200 motor-correct???
    Previously Owned:
    1981 ATC 185S
    1984 ATC 250R
    1981 ATC 250R
    1983 ATC 110
    TRIKELESS
    Jan 2014
    Massachusetts USA
    782
    Quote Originally Posted by 3wheelrider View Post
    The stock 200X brake pedal uses the clutch cover as its mounting point. Once you go to an auto-clutch engine, the cover no longer has that provision and a custom pedal setup has to be fabbed, or change to a handbrake. I have read that 350X pedals fit onto the 200X footpeg boss with basically no fab work needed to keep the rear brake foot-activated. If you search, there's a thread on here somewhere.
    1985 Tri-Z 250
    1985 ATC250R
    Apr 2015
    Brownsville, CA
    34
    I used a 86 200x foot brake and used a piece of black sheet metal to move the rear master cylinder left a couple inches to meet up. I do need to also weld a small ber to adjust the foot action further out.
    Jun 2006
    Omaha Nebraska
    321
    Correct, I just grew up on an atc110 and never used the foot brake, always the left hand. I am going to try out the left master cylinder for the rear and keep the right master cylinder for the front to see how it plays out. I was also considering running just the right master cylinder with a "T" to run both front and rear but did not want to have all controls on one hand like you had stated.
    Aug 2014
    South Louisiana
    1,915
    I have 2 hand brakes on my super x and they work great. Controlling wheelies is a little tricky at first. Getting back on a bike with conventional brakes you have to remind yourself of the foot pedal.
    "Roll on 3"
    RIP Ol' Deuce
    "Long Live the ATC"
    Building: ATCr125x
    Riding: ATC200sx
    Surprise, AZ
    2,428
    You could run a double stack banjo bolt and have a left handed brake & rear brake pedal at the same time.
    Aug 2014
    South Louisiana
    1,915
    Quote Originally Posted by onformula1 View Post
    I did think about doing that and I had all of the quad front brake parts but sleezbay was running deals on the set of masters...
    "Roll on 3"
    RIP Ol' Deuce
    "Long Live the ATC"
    Building: ATCr125x
    Riding: ATC200sx
