Results 46 to 60 of 67
Thread: ATC 110 build
  1. #46
    1979atc's Avatar
    1979atc is offline At The Back Of The Pack Arm chair racerFirst time rider
    Jun 2015
    NW Ohio
    213
    The piston I have is a 15mm wrist pin, did some comparing with pistons my dad has and we figure that it may be a 118 piston. Thanks
    1979 Atc 110 helm and son
    1977 Atc 90
    1980 Atc 110
    1984 Atc 110
    1985 Atc 110
    1988 XR 200 bored 40 over,
    Atc 200x bottom end.
  2. #47
    1979atc's Avatar
    Jun 2015
    NW Ohio
    213
    Here is what the build looks like so far, I had a BAPP 55 tooth rear sprocket and a BAPP chain tensioner I put on today. I just have the motor sitting in the frame until I can find a 123 piston for a good price, or just be able to find rings for a 118cc piston. That would save me from boring the cylinder also. My 3 bolt rims I will be getting sand blasted, and put flat tracks on the rear, instead of having these big knobby tires on the rear.
ID:	228663Click image for larger version.
ID:	228664Click image for larger version.
    1977 Atc 90
    1980 Atc 110
    1984 Atc 110
    1985 Atc 110
  3. #48
    1979atc's Avatar
    Jun 2015
    NW Ohio
    213
    Have a few more things to add, lightened flywheel, (not finished yet) and got a BAPP intake manifold, I am putting the BAPP intake on my H&S trike, will be putting a sudco on this current build.
ID:	229135Click image for larger version.
    1977 Atc 90
    1980 Atc 110
    1984 Atc 110
    1985 Atc 110
  4. #49
    1979atc's Avatar
    Jun 2015
    NW Ohio
    213
    Here are some pictures of my first build H&S trike, and I recently just put on a BAPP long intake on. My other build that is going to 123cc is currently still down, still waiting for some parts, got a web 99 cam, 123cc piston and 3in vintage wheel spacers coming for it. Thanks
ID:	229580Click image for larger version.
ID:	229581Click image for larger version.
ID:	229582Click image for larger version.
    1977 Atc 90
    1980 Atc 110
    1984 Atc 110
    1985 Atc 110
  5. #50
    The Open Road
    4,736
    You got some pretty sweet stuff on there. Nice rides too.
    Sent from my Z998 using Tapatalk
  6. #51
    1979atc's Avatar
    Jun 2015
    NW Ohio
    213
    Another update. I have been in the process of making fork extenders. I just got a set finished and have installed them. I like the look and it handles a lot better. Click image for larger version.
    1977 Atc 90
    1980 Atc 110
    1984 Atc 110
    1985 Atc 110
  7. #52
    1979atc's Avatar
    Jun 2015
    NW Ohio
    213
ID:	231048Click image for larger version.
    Here are some pictures of my piston, can anyone identify the brand of the piston. The cc is unknown at the moment. Pictures show all the symbols on the piston. Thanks
    1977 Atc 90
    1980 Atc 110
    1984 Atc 110
    1985 Atc 110
  8. #53
    6,809
    Looks like a PK piston that's been stroker cut to me
  9. #54
    1979atc's Avatar
    Jun 2015
    NW Ohio
    213
    Thanks Mike! Sent measurements to Jwheeler hope I can find out what cc this piston is so I can get rings.
    1977 Atc 90
    1980 Atc 110
    1984 Atc 110
    1985 Atc 110
  10. #55
    Jun 2013
    Oceanside, CA.
    612
    As Mike states the original designed piston had been modified to be used in a stroker crank motor. If used expect it to knock, make louder piston noise as the normal clearance is going to be larger due to shorter piston skirts. Easy enough to measure piston size, measure across bottom of piston skirt, add @ 0.004 for clearance and convert to millimeter.
    ’84 YT60
    ’89 TRX250R (stock )
    ’90 LT500 Quadzilla
  11. #56
    1979atc's Avatar
    Jun 2015
    NW Ohio
    213
    Here are some goodies! Anyone recognize what in the left hand bottom corner? Click image for larger version.
    1977 Atc 90
    1980 Atc 110
    1984 Atc 110
    1985 Atc 110
  12. #57
    6,809
    Yep it replaces the points set up , cool old school parts !
  13. #58
    1979atc's Avatar
    Jun 2015
    NW Ohio
    213
    I seen only one other one and you posted it Mike. Wish I could take all this stuff off my Fathers hands! More to come when we find his other stash!
    1977 Atc 90
    1980 Atc 110
    1984 Atc 110
    1985 Atc 110
  14. #59
    6,809
    Well if you want one for your self LMK lol I have no plans for the one I have
    Quote Originally Posted by 1979atc View Post
  15. #60
    1979atc's Avatar
    Jun 2015
    NW Ohio
    213
    Been wanting to share this with some of you for awhile, and today I could finally get a picture of it in the daylight. My father's old modified race bike, it all needs put back together. This is a fully suspended bike, This thing is very wide, wider than legal limit I was told. The motor that goes in this is a stroked 210cc 185s motor. Huge stage 2 cam, 32mm carb I believe went on it. Had a supertrapp full exhaust system and a lot of other goodies. He still has all the old parts that went on it. Packed in our several barns of parts, lol. We plan on restoring this bike someday, or get it all back togther and running again. Has been part for awhile now, ever since I can remember and I'm 17 now. Thanks!
    1977 Atc 90
    1980 Atc 110
    1984 Atc 110
    1985 Atc 110
