Well, I knew at some point the engine would blow and I would be rebuilding. When I bought it, I decided instead of putting a lot of money in the engine to make it "last longer" that I would have fun and run it until it dies... which happened this weekend. We are at the last couple miles of our 50 mile ride that morning.... I made it 49 1/2 miles.... If you want, you can watch it happen here... https://youtu.be/0_Sm9WzoN5w
Now that its done, its time to rebuild. I will start by saying I realize I will have way more money in this trike than it will ever be worth, but, I am doing because I want to do it not because I want to sell it. Having said that, here is my list (as it stands today anyway) of some of the things I want to do to it. If any has any suggestions on what to do, what not to do, or what to buy versus rebuild, please chime in.
1. Engine - It will be going to Brenden Yeager for a complete rebuild top to bottom and powder coating. He will be putting a Big Bore 350 top end on from Harry Klemm. Brenden mentioned a guy that makes custom pipes... depending on price I might get a totally custom pipe and silencer built for it.
2. Carburetor - I have plenty of time to change my mind, but as it stands right now I plan to use Keihin 38mm air striker
3. Power Reeds - V Force Reed kit with Boyesen reeds
4. Air Filter - Current Stock Airbox with current (and brand new) K&N Filter
5. Radiator - GPI Racing Aluminum Radiator and all new hoses
6. Billet Water Propeller
7. Thermostat - I want to see about finding a newer than 30 year old thermostat that will work.
8. Adding Gauges - I want to figure out a way to add a Temperature gauge or 2 so I can keep a close eye on the engine temp and coolant temp. I never want to seize up again due to overheating. Would also like to add a tachometer if possible. Speedometer would be cool too.... but, the temperature gauge is a must
9. Swingarm - I am looking for a +4 swingarm. Also looking for either aftermarket axles (preferred) or wheel spacers that would add 3~4 inches of backend width. I contacted RODZ Swinger's Customs to see if they make one.
10. Tires - I am going to lose the 22" scorpions and do to 20" holeshots. Not sure about the front yet.
11. Sprockets and Chain - Definitely going to replace, but, I have NO clue what I am going to do on those yet.
12. Brakes. I want to either rebuild the master cylinders or use something from a newer-than-30-year-old machine that would work.
13. Wiring - I will take this opportunity to completely rewire the trike. Also, hoping to add a "blinking" brake light.
14. Cosmetics - Jason Tetz is going to make a set of Carbon Fiber fenders. I am talking with a couple of custom seat makers to make a unique seat for me. I will be getting the Wicked Metal Designs foot pegs and having a custom fab shop make a set of nerf bars to my liking. I will be using the Mika Metals hybrid handlebars with the holeshot cell phone holding crossbar pad. Will be powdercoating the frame candy apple red. Wheels will be powdercoated gold as well as the swing-arm.
15. Will be replacing all bolts and bearings
16. Shock - Looking at having a "franken-shock" built for it by zmpolaristech
17. Front Forks - Should I replace them? Rebuild Them? I know very little about them.
Right now I am in the planning / dreaming stage. Any comments or suggestions would be appreciated. My goal is that when it is done it will be a "new" trike. Even things that are "good enough" for now, I would rather go ahead and rebuild or replace so that when it is done, I will know that from "said date" all was new and won't have to wonder when the next thing is going to break because it is still 30 years old.
[/SIGPIC]
