Results 1 to 12 of 12
Thread: Engine serial number help
    Apr 2017
    Cloud 9 Ranch
    13
    I have tried to be self sufficient however I cannot find the serial number on a 200x motor. Any help?
    The Open Road
    4,736
    Way down on low left side under the shifter shaft
    Apr 2017
    Cloud 9 Ranch
    13
    Ok in the stamped box between the shifter shaft and the oil drain plug?
    Mar 2017
    Maine
    52
    example of mine on my 200x motor... this is the left side view under the shift lever.
    Sent from my XT1585 using Tapatalk
    The Open Road
    4,736
    Quote Originally Posted by doscientosX View Post
    Yes
    Apr 2017
    Cloud 9 Ranch
    13
    Well it is that easy but in my case not. I saw the box and cleaned it well and looked with a flashlight, nothing. Took a piece of sand paper and cleaned off the paint, nothing. So I am assuming the numbers have been rubbed off for some reason. Got this motor in a trade a few years back, don't know the history. Guess I'll do the best with what I know on seeing it is the same as my 84 and using the jug off it in my rebuild.
    The Open Road
    4,736
    Take a pic of it and post it up.
    Only reason I can think of for there to be no numbers is that perhaps it's an OEM replacement case half. I know some MC and small engine manufacturers sometimes left the serial pad blank on replacement case halves.
    Apr 2017
    Cloud 9 Ranch
    13
    This is what I have
    Slidell, LA
    4,738
    Yeah that sucks, it's been removed
    Apr 2017
    Cloud 9 Ranch
    13
    Well it ment something to someone at one time. Not a stock piston and a copper head gausket. I wonder it's true story......
    2,591
    It also looks like it dropped the exhaust valve.
    6,810
    A new replacement case from Honda wouldn't come with any numbers . Not that uncommon.
    I went threw a half dozen left side cases while racing back in the day .
