Page 247 of 313 FirstFirst ... 147 197 237 245 246 247 248 249 257 297 ... LastLast
Results 3,691 to 3,705 of 4686
  1. #3691
    The Open Road
    4,736
    I sure wish you were selling these.
    A good quality custom made replacement is worth $100- $150 to me. Screw the Chinese ones
  2. #3692
    DDQ's Avatar
    DDQ is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    May 2015
    Aberdeen, NC
    429
    Sent from my SM-G975U using Tapatalk
  3. #3693
    Apr 2020
    Yakima, Washington
    44
    I will be doing year end maintenance on my te300i snow bike. I think we are done riding for the year
  4. #3694
    Cold Lake, Alberta, Canada
    3,019
    ^ Sorry for your loss.........of snow. I can't wait for this shiite to be gone, lol. Cool bike btw, looks like fun!
    ^^ DDQ, wouldn't want to camp anywhere near that gen set........what is someone thinking!
    Trikes
    1970/71 US 90 (Aquarius Blue)
    1972/73 US 90 Green
    1982 ATC 70
    1983 ATC 70 (Ladybug)
    1973 ATC 70
    TF 2015
    Other
    1983 Honda Z50
  5. #3695
    May 2015
    San Diego, CA
    1,800
    Quote Originally Posted by kb0nly View Post
    The CDI on my 82 200E was acting odd, spark then no spark, decided enough is enough, time to pull the CDI off and go build another one of my design to put on it. Got the PCB built, box made, tomorrow i will get it potted and put on and no more intermittent spark! Yeah i know, they are available fairly cheap now days, but i prefer to build my own and control the quality of the components in it, they run much better then the cheap ones.
    Attachment 267090
    Attachment 267091
    It would be nice to get one for a DR650......First gen.
    It's hit and miss on ebay for a used one
  6. #3696
    MN
    3,263
    I thought about it, problem is i don't have enough time for another side business building these... LOL... I have made a few and sold them to guys locally fixing ATC's and older Honda quads, but they are all hand built one at a time, i even test the components to bin the caps for their quality before building them into a CDI.
    Today i potted it, i have taken apart OEM CDI's and they always seem to be sitting on the bottom of the box with no potting or very little between the PCB and the box, it should be fully encapsulated. I pour some in the box, give it 10-15 mins so the stuff at the bottom starts to firm up then put in the board and pour in the rest, if you get the amount just right it will fill up the bottom of the connector shell and around the contacts and the little channels in the connector shell, a good watertight seal. I haven't had one fail yet, the ones i have made will probably outlive me since some of the OEM ones are still kicking 40+ years later.
    If i get some time someday i should build a dozen of them and just keep some stock on hand in case guys need them. Not sure what i would sell them for, i put more time and labor into them then they are worth probably, but i demand quality out of these. I burned through three chinese ones on my 200ES before i built one and put it on last summer, i've made close to 20 of these now for myself and others locally. So far so good!
    1984 Honda ATC200ES "Big Red"
    1982 ATC200E "Hondie"
  7. #3697
    MN
    3,263
    Quote Originally Posted by DDQ View Post
    That is just insane... LOL
  8. #3698
    MN
    3,263
    Those Suzuki CDI's are a bit of black magic... I have seen the insides of one, there is a lot more going on with the circuity in them. Would have to get one down to bare PCB and reverse engineer it fully first. Who knows maybe it is a pretty basic CDI with a lot of extra buildup on it, not sure, but i do know guys on other forums that have fought Suzuki CDI's and their replacements.
  9. #3699
    May 2015
    San Diego, CA
    1,800
    Quote Originally Posted by Minter fab View Post
    That's a sweet looking machine.
    It reminds me of Robbie Maddisons KTM on water.......he's got more guts on one hand than I do in my entire body. I always wondered what would happen if the bike died while on the water for whatever reason.... I'm guessing it would sink like a dumbell and another KTM would retire to the deep.
    https://youtu.be/lDi9uFcD7XI
  10. #3700
    Williamstown PA
    5,825
    I dicked with my 300x build more. Frame nearly doneClick image for larger version.
  11. #3701
    2,447
    Replaced the radius arm bushings on my pickup. I put some poly ones on it years back and that's just a poor application for poly bushings. Both the rear sections cracked.
    Attachment 267141
    Attachment 267143
    The radius arm bushings function completely different from other suspension pivots. They are under compression and have to actually flex. The poly just isn't suited well for it, so I went back with rubber.
    Attachment 267142
    Attachment 267144
    This is a two wheel drive, manual steering pickup, and I can actually feel the difference between the two bushing materials. The rubber handles and rides better. The poly doesn't let the suspension flex properly and quickly and small road vibrations really travel through it. I've replaced the rivets on the brackets with bolts, so replacing these is a half hour job and doesn't even require a jack. If the rubber ones are done in five years, it's no big deal to replace them. The radius arm bushings on Ford twin I-beams are a huge part of keeping the front end aligned and working properly, and I'm going to stay with rubber on any of them from here on out.
    Oh, and I got a little gravel road trike riding in during the weekend. No trail riding though.
    Attachment 267145
    Attachment 267146
    Attachment 267147
    Attachment 267148
  12. #3702
    Mar 2009
    new england
    1,391
    Prices are plain silly! I needed some pine. In the past, the mill (like reloading) was more for fun>cost savings. Now fun=cost savings!
    Took the Peterson out and cut up about 45 3.75x1x96
    Fun couple of hours in the nice weather, then back in storage
    Such a useful machine
  13. #3703
    2,447
    Isn't odd how lumber prices have shot up, but log truck drivers aren't making any more? They're actually being squeezed by the fuel prices and no increased pay per load.
    Friend of mine has a couple trucks and we were discussing it yesterday, with another driver he knows. Funny thing is if they stopped hauling the timber out of the forest, the whole system would be affected...
    Of course, the system works by keeping the little guy barley getting by so they can't stop, or they'd loose everything. At some point though, there is nothing to loose, especially when all they're making is just enough to pay bills. Most people would crap themselves if they knew how little log truck drivers got per ton, versus what one 2x4 cost.
    Just the cost of regular maintenance on those trucks is staggering.
  14. #3704
    Mar 2009
    new england
    1,391
    Ya, friend is an owner operator
    Tough racket
  15. #3705
    2,447
    I replaced the trans pan on my car's TH400R with an aftermarket aluminum one, and that premium Moroso gasket. Then I made about a 35 mile trip and parked it in the shop afterwards. If there's a spot on the floor in the morning, I'm going to pull my ball hair out.
