Results 1 to 15 of 16
Thread: Tri-Z 600 conversion - Part 2
    Oct 2007
    Chester U.K
    68
    here's the latest pics, i can't get a side on shot yet cause she's not mobile - please keep dropping into to this thread because i'll need your experience & advice as i align the sprockets etc. going shopping for a rear shock 2moro
    Tri-Z 600 streetfighter
    Willamstown PA
    5,820
    how are you going to shift if the stock shifter will be behind your heal?
    linkage similar to a warrior? with a toe, heal shifter?
    very nice work on the swinger by the way!
    Did you extend your dog bone so it sits right with the shock.. that looks to be the next step..KILLER!
    nice upper tripples..I used CF
    Oct 2007
    Chester U.K
    68
    i'm not using the stock shifter & will post pictures soon of the new one i've made along with the stretched brake pedal. I cut the swinger after the dog bone to avoid tig welding, the new shock needs to be a couple of inches shorter to make up for the new rake.
    We spent hours last night looking at the sprocket alignment, overall judgement is as its only 4mm out so a small spacer will pull the chain over - that was more luck than judgement
    Columbia
    5,131
    Man Dee,
    It looks awesome!!!
    Good job so far, I cant wait to see it in action!
    Oct 2007
    Chester U.K
    68
    thanks Eric. I went to my local breakers to find a rear shock, after a long debate with the owner I bought a Showa with a remote canister which we think came off a CBR 600. I'll finish off machining the dog bone today, fit it & drag here outside so I can get a side on pic to post up. Getting close now
    250rfreak's Avatar
    250rfreak is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Nov 2007
    UT
    330
    that looks bad ass
    famous words "is it wrong to wear my helmet sitting on the toilet and twisting the toilet paper roll like its a throttle while making engine noises?"
    Oct 2007
    Chester U.K
    68
    here it is, gonna play with the ride height next then fit the electrics
    Dec 2003
    australia
    838
    Looks pretty cool
    I hope you can get it to handle nice.
    I've got those tyres for motard on my quad. You will need to ensure the tyres and rims are balanced as they can vibrate at high speeds.
    Aug 2005
    Lockport, NY
    2,395
    where did you get those tires?
    Oct 2007
    Chester U.K
    68
    http://www.tyre-rite.co.uk/searchres...rds=Speedracer
    I think they come from your side of the pond, Kenda Speedracers? They were the only tires i could find that were road biased & in 12"/8"
    250rfreak's Avatar
    Nov 2007
    UT
    330
    what are you going to do about the gap between the tank and seat?
    Oct 2007
    Chester U.K
    68
    i'm going to plastic weld two tanks together, should look o.k when done
    Sep 2007
    British Columbia, Canada
    818
    Man, that thing is long!
    Looks awesome though, great job so far!
    [b]'83 200X-
    White/Blue:
    The 2 stroke 200X
    Vids:http://youtube.com/watch?v=HwDqUVM9jOo
    Dec 2006
    red neck land mn
    22
    thats so sweet
