Results 1 to 15 of 15
Thread: What year is my 185s?
    Aug 2004
    Nampa, Idaho
    1,245
    I have a 185s but I'm not relly sure what year it is. Its two piece wheels, rigid frame, the rear plastic fenders split into two pieces , and its got a small trunk lid behind the seat. I was thinking it could be an 82 but it might be older. I can seem to find the VIN numbers.
    Current rides
    83 185s
    06 Rancher ES
    95 Ford F150 4X4
    2000 Ford Explorer Sport
    Tionesta, PA
    5,743
    Must be an ATC200. All 185Ss had one piece fenders. ATC185 was only made for one year and had a round headlight - but it did have the same rear fenders as the ATC200 - but they were more orange in color. I am guessing that is an ATC200 with a 185s tank.
    Check the engine for a CM3 size cast in for engine size.
    Aug 2004
    Nampa, Idaho
    1,245
    What year did they change from points to CDI?
    Current rides
    83 185s
    06 Rancher ES
    95 Ford F150 4X4
    Aug 2004
    Nampa, Idaho
    1,245
    The square headlight could be off of something else because the brackets are welded onto the forks and it does not look stock.
    Current rides
    83 185s
    06 Rancher ES
    95 Ford F150 4X4
    Tionesta, PA
    5,743
    as far as I know the 185 / 200cc motors never had points - they are all CDI. My 1980 ATC185 has CDI ignition.
    BTW - that is a 1982 gas tank - but as I mentioned - the rest of the machine is an ATC200. The fenders and 9" wheels give that away. ATC185Ss all had 8" wheels and one piece rear fenders. Also - that is an ATC200 seat.
    Aug 2004
    Nampa, Idaho
    1,245
    That means that I probably have two 200's and only one 185. Where is the VIN on your 1980 ATC185?
    Current rides
    83 185s
    06 Rancher ES
    95 Ford F150 4X4
    Tionesta, PA
    5,743
    Quote Originally Posted by firehart View Post
    on the neck - where the steering stems goes through. Should be stamped in.
    May 2008
    Northwestern Ontario, Canada
    552
    The paint scheme on the tank is an 82 for sure and the light is does NOT look original! Post the VIN I can tell you for sure when I'm back at work tomorrow!
    My Trikes...
    -1985 Big Red
    -1986 250r
    -1984 200x
    -1980 110
    -1980 ATC 185
    Russell 350X's Avatar
    Mar 2003
    Steamburg/Randolph NY
    3,092
    Thats deff. a 82, solid forks, the tank scheme is 82, and a square headlight, if it was pre-82, the light would be round.
    TF 07,08,09,10,11,12,13,14!
    Tionesta, PA
    5,743
    Quote Originally Posted by hondaatc185S200E View Post
    1981 had a square headlight. 1980 was the only 185 with a round headlight. The only other Hondas that had round headlights were early 110s and late 90s. That is not the right headlight on that machine.
    Mar 2003
    3,092
    Good call, I forgot about that.
    Sep 2007
    100mi west of Chicago
    3,582
    I agree with atctim that it's a 200 with a 185s tank. The only year that had a 185 engine with the split rear fender is the '80 185. 1981 to 1983 185s is all one piece.
    Rob
    Dec 2002
    374
    i am not sure what year your machine is, but she sure is a beauty
    Nov 2006
    Geraldton, Western Australia
    81
    which model 185s
    this is from atcheaven.com parts section
    Introduction of ATC185, first model to graduate from "pressed steel" to "tubular frame" Nice bike with plenty of horsepower that was lacking in previous models. Seperate rear fenders with tool box, this model targeting the "Work Horse" market. 180cc engine, 12v electrical system.
    Engine Number TB01E-2000013~
    ATC185 models became the ATC185S in 81, "S" denoting sports, new tank design, 1 piece rear fender, round headlight replaced with rectangular unit, tail light and rear carry rack revised. Brake drum enclosed within cover plate, minor difference in rear axle.
    Engine Number TB01E-2100001~
    Few changes worthy of note for 82 models, decompression cable incorperated into pull starter, kill switch goes from top of thumb throttle case to left side combination switch, new design air cleaner & air box, tank and rear fender decals change. Headlight switch moved from top of headlight to bar mounted combination switch
    Engine Number TB01E-2200001~
    Last year of production for the ATC185S. 83 models get new "Front Suspension" fuel tank shape gets smoothed out, air cleaner and air box get re-designed, rear sprocket gets revised damping arrangement, front & rear rim becomes one-piece, minor changes to front brake panel
    Engine Number TB01E-3000008~
    Jan 2008
    Oregon
    29
    Looks like my 1982 185s with a square head light that I have in my garage.
    My guess is it's an 82 185s..
    CrazyK
    1983 Honda 185s
    1985 Honda 125 TRX
    1986 Honda 200 AutoX
    1986 Honda 350X
    2002 Honda 750 A.C.E
