Results 1 to 14 of 14
Thread: atc 70 with a overdrive
    Kilgore, Texas
    78
    I got this idea to put another tranny in my 70 behind the existing engine/tranny. I cut it all apart from the crankcase tonight and i need to get it welded where it holds gear oil then mount it. im going to cut holes in the sides of the body where the 2 shafts will come out. i flipped the axle around and im putting disk brakes on it so i wont have to worry about swapping brake sides also. any one ever tried this?
    1-86 350x runs decent- stolen
    1-85 350x rough but runs strong 80mph per gps
    1-85 350x completely restoring-frame blasted and painted
    2-85 350x frames with engines messed up
    1-85 atc 70 runs been in storage most of its life
    Feb 2008
    Orange County California
    726
    no, but sounds like a mad scientist thing to me. Post some pic's, I want to see what you are talking about. Having a hard time visualizing it.
    1986 ATC250r
    1984 ATC70
    Kilgore, Texas
    78
    i will post some pics today
    Mar 2007
    Texas
    5,045
    ________________
    https://www.mikesatvfix.com
    Nov 2004
    Waterloo IL
    2,701
    I see what you are saying but I think its going to provide more underdrive than anything. If 4th in a stock 70 is an overdrive (higher ratio than 1 to 1) you might get slight OD if both transmission are in 4th but that probably wont gear you up much.
    08 Outlaw 525s
    07 CRF70
    04 Harley FLHRCI
    04 TRX90
    03 XR650R
    03 400EX- XR650R engine
    02 XR100R
    01 Banshee
    00 XR50R
    00 XR70R
    99 PW50
    99 JR50
    96,95 Sportsman 400
    95 Xplorer 400
    94 Indy XLT
    87 Trail Boss
    86,86,86,86,86 Scrambler
    86 TRX70 x2
    85 ATC350X
    85,84 ATC250R
    85 Red Tecate
    85 LT50 x2
    84 XR500R
    84,84,84,84,83,82,80,79 ATC70
    82,79 XL500R
    83 ALT50
    79,78,77,77,76 XT/TT500
    76,75,74 XL70
    72,71,71,71 SL70
    72 Harley FX
    72,71,70,70,70,70,70 CT70H
    72 SL100
    70,69 Z50
    Billy Golightly's Avatar
    Live Oak, FL
    15,070
    We do this with swamp buggies down here all the time to get enough gear reduction. Engine/Trans/Trans2/Transfer/Rear. Never seen or heard of it being done in a trike or quad though.
    Definitely interested to see how it turns out!
    Kilgore, Texas
    78
    i know what your saying but a stock 70 has 2 gear reductions in the final drive. a 4-1 from clutch to trans then trans to output is a 2-1 so im going from output on trans1 to output on trans2 and final will be the input on trans 2 to rearend so gearing up 2-1 i believe. we had talked about turning it around and getting more underdrive but i dont think a 70 needs any lower
    Quote Originally Posted by Blown 331 View Post
    Nov 2004
    Waterloo IL
    2,701
    Quote Originally Posted by big_daddy124 View Post
    I still think you are going to get more underdrive with it than you will overdrive. But if that is the case you could always gear it way up on the sprockets which would give you a lot more top gearing and still be ok with all the underdrive. If someone looks up all gear ratios in a 70 you'll have your answer. I'm betting 4th is an overdrive so you will gain some but in the case that 4th is a 1 to 1 ratio. When you hook 2 transmissions together that are 1 to 1 in 4th, well it's still gonna be 1 to 1 and you won't gain any OD at all. Just a bunch of underdrive. Example if 1st gear is 4 to 1, putting both transmissions in first will cut that 4 to 1 down by another quarter. If any of that made sense.
    08 Outlaw 525s
    07 CRF70
    04 Harley FLHRCI
    04 TRX90
    03 XR650R
    02 XR100R
    01 Banshee
    00 XR50R
    00 XR70R
    99 PW50
    99 JR50
    96,95 Sportsman 400
    95 Xplorer 400
    94 Indy XLT
    87 Trail Boss
    86 TRX70 x2
    85 ATC350X
    85,84 ATC250R
    85 Red Tecate
    85 LT50 x2
    84 XR500R
    82,79 XL500R
    83 ALT50
    76,75,74 XL70
    72,71,71,71 SL70
    72 Harley FX
    72 SL100
    70,69 Z50
    Kilgore, Texas
    78
    yea it makes sense if your running them both the same but say first is 4 to 1 and im using the output of my gearbox as the input it should be 1 to 4 right? since the thing factory is gear reduced i am turning it around and making it gear up. fourth is 2-1 none of it is actually 1-1
    Nov 2004
    Waterloo IL
    2,701
    OH, you are correct then. I mis-understood. Yeah if you put the second trans in backwards then you will have several OD gears. Sounds really interesting if you can pull it off and have the power to pull it. Good luck!
    08 Outlaw 525s
    07 CRF70
    04 Harley FLHRCI
    04 TRX90
    03 XR650R
    02 XR100R
    01 Banshee
    00 XR50R
    00 XR70R
    99 PW50
    99 JR50
    96,95 Sportsman 400
    95 Xplorer 400
    94 Indy XLT
    87 Trail Boss
    86 TRX70 x2
    85 ATC350X
    85,84 ATC250R
    85 Red Tecate
    85 LT50 x2
    84 XR500R
    82,79 XL500R
    83 ALT50
    76,75,74 XL70
    72,71,71,71 SL70
    72 Harley FX
    72 SL100
    70,69 Z50
    Kilgore, Texas
    78
    lol i am glad it makes sense to someone other than me. i trimmed all the engine away from the gearbox/tranny now i gotta get the sides welded up and fabricate a removable cover so i can repair it if ever need be. i will post pics soon
    KASEY's Avatar
    KASEY is online now weee weeee weeeeeeeeeee ! ! ! The day begins with 3WW
    ARIZONAS BIGGEST TROUBLEMAKER
    4,249
    WHY ,,, 70's don't have enough power to pull a tall 4th gear anyway,,, with an adult on it,,, going up 2 teeth on the countershaft will achieve the same thing...
    Apr 2006
    PA
    1,464
    Its been done on 4x4s before, but the gear box was bolted to the hub which spun the gears inside to another hub on the bottom which geared it lower.
    Dec 2005
    Wisconsin
    1,141
    Sounds cool. Reminds me of the old 2 stick semi's used to gave. Grab one lever, go grab the next go again, grab another, just don't grab both and screw up lol.
    YTM-200, Wheeling machine!!!
    1985 Honda 200x...
    ...Just a simple mild 200x
