Results 1 to 10 of 10
Thread: Tire leaking at the bead, what are my options?
    Nov 2002
    Kirkville, NY
    3,831
    I put some old Holeshots one a set of steel rims so I can stud them. They leak at the bead, what can I do? Is there a bead sealer or something I can use? I am looking for cheap. They don’t have to hold air forever, just a few races at a time.
    2004 BMW R1150R
    1972 Honda CT 70
    2007 Lifan 110
    Aug 2004
    Nampa, Idaho
    1,245
    Did you wire brush the wheel and put a little liquid soap around it?
    Current rides
    83 185s
    06 Rancher ES
    95 Ford F150 4X4
    2000 Ford Explorer Sport
    bad350's Avatar
    bad350 is offline At The Back Of The Pack Arm chair racerFirst time rider
    May 2008
    kentucky
    176
    i always put a bead of 100% silicone on the wheel where it seals, then reseat the tires
    Jul 2006
    Quote Originally Posted by bad350 View Post
    werd, I use windsheild eurathane (the cheapone)
    Nov 2007
    ulysses pa
    1,231
    grease, silicone, liquid nails. or i know carquest has some bead sealer. not sure on the price but it works well. napa also carries it but its around 18.00 a tub.
    Tekawte1's Avatar
    Tekawte1 is offline At The Back Of The Pack Arm chair racerFirst time rider
    Aug 2007
    Indiana
    176
    bead leak....
    Well for starters i would never mount a tire to a chitty bead.. your just askin for a leak. Clean it of all rust and or debris first and paint it. nice clean best way to get it sealed.. now if you are using some old tires that may not have the greatest bead lip, mount em with some tire patch sealer or some silicone. just dont mount em with a super stong glue or something compareable to permanent if you plan on takeing them off ever.. I dont recommend grease due to the tire slipping on the rim and then could cause another leak. Is pretty cut and dry.. if ya got a leak seal it with some thing that will hold but use something that you can take off if needed..
    Trikes make me drool TRIKEFEST 08 survivor And Sandpuppies 08 survivor
    Decent thoughts here, but I wouldn't use grease either and soap only seals so much....
    I like the person that in another post suggested Slime only on the bead sealing area. I'm gonna give that a shot myself!
    Apr 2006
    Crestview, Florida
    2,429
    I must be retarded, i use Bead Sealer.
    Rides
    85 ATC350X
    85 ATC200X
    st joe
    143
    bead sealer!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!
    " 2 STROKE 4 LIFE "
    85 Yamaha tri-z 490 dirt dragger
    86 Suzuki lt 250r (every day rider)
    92 Suzuki lt80 (daughters dirt dragger)
    96 Polaris trail blazer 250
    Nov 2002
    Kirkville, NY
    3,831
    Is bead sealer the stuff that glues the tire to the rim making it soooo hard to remove later? I have had tires that have been glued to the rims with thick black stuff before, that sucked.
    2004 BMW R1150R
    1972 Honda CT 70
    2007 Lifan 110
