Results 1 to 15 of 30
Thread: any luck welding shifter lever?
    rebel33382 is offline At The Back Of The Pack Arm chair racerFirst time rider
    New Orleans, LA
    201
    my lever is stripped, and I dont have the factory shift lever, was going to order a new one and weld it on, anybody have any luck with it or am I wasting my time?
    1984 200ES first Shaft driven big red with reverse!
    85 Big Red 250ES with a rebuilt top end!
    Hampton, Virginia, C.S.A.
    2,664
    i have a shifter welded on one of my 200s's it works fine...just make sure its exactly like you want it and comfortable for you the shift with befor you weld it
    current rides
    82' ATC110
    85' ATC310R
    85' ATC250R
    85' ATC250ES
    16' brute force 750
    PA
    3,515
    just replace the shifter shaft, its not that hard to do now.
    try to take the case off after you weld it......
    WWW.HREATV.COM
    Shawn72's Avatar
    Shawn72 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Jul 2006
    Lawton, Ok
    392
    Not a good idea. If you weld it and the lever breaks you're up creek. You can get a shift lever off ebay for very cheap. If it's a Big Red they come a dime a dozen. Maybe 20 bucks and you're in business.
    It's a celebration bitches!!!
    Jul 2006
    iowa
    451
    up creek? i dont see why. a lot of trikes have a good amount of shift shaft sticking out from the motor so you should be fine. Weld the damn thing on. if you have to take the case off later on, well then your gonna have to use an angle grinder for a minute, instead of a 10mm wrench for 30 sec.
    current rides:
    05' 400ex
    02' yz85
    84' 200es big red
    84' 200s with tlr200 engine project (almost done)
    84' atc 110
    83' 225dx with 340cc kohler sled engine
    braunz200x's Avatar
    braunz200x is offline At The Back Of The Pack Arm chair racerFirst time rider
    Toronto
    158
    Shawn72's Avatar
    Jul 2006
    Lawton, Ok
    392
    Quote Originally Posted by hondahaulic View Post
    Well, there's your choice. Spend 20 bucks now or buy an angle grinder a shift lever and shift shaft later. Easy choice for me.
    Oct 2007
    Grosse Tete, LA
    3,440
    I hate people who cobble stuff together...do it once, do it right, the end....
    Shawn72's Avatar
    Jul 2006
    Lawton, Ok
    392
    Quote Originally Posted by The Goat View Post
    Couldn't agree more
    May 2007
    Coshocton, Ohio
    1,815
    Quote Originally Posted by rebel33382 View Post
    If you are spending the money to buy a new shifter why would you even consider welding it on? A new bolt should be fairly cheap. Just bolt it on there and be done with it.
    Appalachian American Racing
    the home of
    New Orleans, LA
    201
    the shaft coming out the case is stripped as well, and I cant find one on ebay, and an OEM one, if its avail, is 72 bucks at mrcycles
    CENTRAL NY
    1,709
    I would put a new shift shaft in, but if your not going to a better way to do it is a set screw. Drill it so half the hole is in the shaft and half is in the hole is in the shifter the tap it for a little set screw, it acts like a key way and you can still remove the shifter and it holds good and tight..
    1985 250R Selveys port job and pipe
    1985 70 piped for lil'freaks
    2001 TRX90
    ATC 90+250R+BEER= Drag Bike
    1984 ATC70 Pit bike
    1984 110 for sale
    Howdy's Avatar
    Celina, Ohio
    10,079
    What model you need the parts for? I can probably hook you up with everything needed.
    Howdy
    Mar 2007
    Texas
    5,045
    i fixed a guy's 110 trike by welding on a peice of rod to the end of the shift shaf thtat was broken, then cut a groove where the bolt needs ot go to tighten the shift lever on and vwala! it's removeable and fairly perminate! he's been beating on it for a couple months now w/o any issues.
    ________________
    https://www.mikesatvfix.com
    Mar 2007
    Texas
    5,045
    Quote Originally Posted by freaksfix View Post
    NO, No NO! this causes the shaft to be weaker and break where you drill it! that's what happened to the guy's I fixed. it stripped, someone used that "set screw" method and then , Oh Snap! Don't drill it and do that. fix it by replaicng parts or as i mentioned welt on a peice of round metal (all thread would work too if needed) (make sure metal is small enough that shifter can slide over it with some slight effort) and grind the back facing side about 1/4 way through and your done!
    ________________
