Results 1 to 15 of 19
Thread: 84/85 exhaust Tecate frame mount
    Apr 2002
    s.w. michigan
    6,498
    this is (as far as i know anyway) how that exhaust stud is supposed to look like
    First thre are of the frame i have on my bench slowly being reassembled, the other is of my rider and exhaust mounted up ~ ready to ride.
    Sep 2008
    Northwest Indiana
    550
    Thats exactley the way it is supposed to look.......!
    1985 KXT250 A.K.A. "Doom"/Multiple Engine Combinations/Jason Hall Inverts/HRE Swing Arm, Cal Fab Swing Arm/Jemco Pipe/Buzz Saw Cylinder, Klemm Research Cyinder/PWK Carb/PVL Ignition/Dura Blue Axle/Mosh Custom Seat
    Mar 2005
    ma
    988
    thats how i've seen it on the 84-85's. the 86's are basically the same just on the other side.
    Billet Triz 250 parts, Case Savers, Engine Mounts, Boost Bottles, Oil Caps, and Shifters, pm me for info
    Shock Rebuilding, PM me for details TRI-Z Shocks rebuilt too
    My Feedback
    http://www.3wheelerworld.com/showthr...k-for-sblt500r
    Aug 2010
    reseda
    26
    where can i find that mount with the ruber? and thank you for the pics and help
    84 kxt250
    07 trx400ex
    Sep 2006
    Northwest Indiana
    1,893
    These mounts are now on the NLA list. Wonder how many people would like a custom made one? It's tough to correctly mount the pipe without looking rigged, and have the necessary "give" a 2stroke pipe needs. sblt500r, you still makin' custom stuff?
    Aug 2010
    reseda
    26
    i would love a custom made one..
    84 kxt250
    07 trx400ex
    Swiney is probably your best bet. He has grafted rubber to metal on intakes.
    Most of us can't vulcanize rubber between 2 pieces of metal. Pipes have to have a little flop to them.........
    OK
    5,450
    I need a couple too.. These things rarely pop up on Ebay. The good one I do have is stripped sooo.. May need 3 :-)
    Rides:
    1982 ATC70 (Lifan manual 125)
    1987 LT80 (piped, widened)
    My feedback thread
    RIP Trace.. Godspeed.
    Sep 2009
    Washington
    553
    John- I hate to be "that guy" but it appears to me that in the 2nd and 3rd pics you're focused on the tank mount instead of the exhaust mount? I know the fourth pic shows your rider with the exhaust clearly mounted in the lower hole.. Am I confused?
    Mitch
    2) 1977 Honda ATC90
    2)1985 Tecate
    2005 Banshee LE
    01 Honda 300EX
    74 Suzuki TC100
    66 Honda 305 Scrambler
    Apr 2002
    s.w. michigan
    6,498
    Dam you GOOD Mitch ! You are right. Hey thephaty, focus on one mount down and picture the exhaust hanger hanger haning from there
    Okay, You all really thnk there is some what of a market for those exhaust hangs ???
    Anybody got a picture of the 86/87 ones to post up )please)
    Sep 2006
    Northwest Indiana
    1,893
    These hangers have to built TOUGH! Heat, stretching, pulling, weight, and the myriad of different exhaust and silencer combos all dictate that it is durable, b'cause mounting positions all vary slightly. Otherwise they will fail in short order. I figured if someone had the skills to do these, it may be worthwhile. The necessity for it to absorb shock and abuse is paramount!. The oem used a rubber similar to what a tire is made from to join the two halves.
    99gsxr750 is offline At The Back Of The Pack Arm chair racerFirst time rider
    Mar 2009
    Eastern Pa
    219
    When were these discontinued? I picked one up from my local dealer a few months ago, albeit a little pricey at $20.
    Apr 2002
    s.w. michigan
    6,498
    Great info Mike ! I just ordered one for 18.06 (add tax) and will be available for pick up in a few days.
    The old part # is superceeded by 920751891 wich represents the "better" one because the originals was prone to separate (i think we knew that right )
    My Kawi guy told me what all those fit, about 15 different machines, mostly motor cycle.
    OK
    5,450
    Quote Originally Posted by jeswinehart View Post
    Awesome news... Thanks John, for the leg work.
    Rides:
    My feedback thread
    Aug 2004
    Phoenix
    1,229
    That is correct, just about all the kx series bikes use that same mount. I just buy them off the KX500 p/n, and they fit both gen tecates.
    Remove all the warning label and let nature take its course
