Thread: tri-z jetting
    jmax857's Avatar
    jmax857 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    bancroft canada
    354
    tri-z jetting
    okay so im just ordering parts for my trike and i want to know what sizes jets to buy, i know that it all depends on your setup, elevation, temperature, blah blah. just wondering a Ballpark so i can order a few bigger and a few smaller so i can fine tune.
    i have a dg pipe and silencer, bored to 70mm, stock reeds, and a clamp on uni filter. its an 86 carb aswell.
    up grade the carb to a pwk.....
    May 2008
    Tenn
    549
    They're not that expensive. 470 is standard. Maybe get the 480, 490, 500 if you're not sure. I don't think going down will be the direction you'll go but you'll have to chop it to know for sure. It would probably not be a good idea to start less than the standard 470 with those mods. Start rich with the clip in the middle slot as a rule of thumb.
    Just-Tri-It
    :Trikes Owned:
    1985 Tri-z's 3
    1986 Tri-z
    1984 YTM 200ERN 1
    jmax857's Avatar
    bancroft canada
    354
    i knew someone was gonna say that.
    i knew it was going to go up in sizes, i just didnt know how far. ill probably order the 480-500, also do you think i might have to go up a size in the pilot?
    zzmegad's Avatar
    zzmegad is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Nov 2008
    North of Chicago
    317
    First, open the carb and see what you got. The 470 is standard for the 85, but I think the 86 is quite a bit lower, i think 320. Also, Raffa, I have been looking for a pwk, I found this new one on ebay. I just dont have enough experiance to know if anything other than jets would need to be changed such as the slide or needle or needle jet. Can you give any advise on starting points with the pwk on the triz? Thanks
    http://cgi.ebay.com/ebaymotors/YAMAH...Q5fAccessories
