Hello tvpierce
WTF did you change your CARB before trying the new CDI, did you think the new carb would make your missing spark return? Please don’t change any “bleepin” thing until someone suggests it. It makes it next to IMPOSSIBLE for at least me to help people that do that and I have a new fancy TV I could be watchin instead of undoing peoples “fubars”. See the info I posted at bottom of post.
I posted the quotes above simply to show whoever is interested how 1 person can have one experience and another can have one that is EXACTLY opposite. I suggest to anyone with a problem that they consider ALL suggestions given and do ALL tests and check ALL things suggested by everyone no matter how unrelated to the problem they may seem to be. Keep in mind, in the end whether your bike ever runs right again or not has no effect on our lives at ALL just yours. Please don’t be like the _____ in the link at the bottom of my post.
Kbonly, below is the post I’m not sure you saw.
The reason I thought his advance might be the the most likely cause of his problem [even though it might seem unlikely] is because of the following.
a. His pipe is getting red hot but it has a mid throttle stumble.
b. The stumble suggests either a too rich or an improper advance condition.
c. The red hot pipe suggests a lean or improper advance condition.
d. The fact that his stumble is at mid throttle [maybe 2500 rpm] suggests to me that it is more likely the timing then the jetting.
e. If a lean condition was causing his red hot pipe condition it would not “stumble” at all, it would have a huge lean spot and have a lean “bog”.
If one thinks this it’s easy to help someone read the following posts, at least the ones with the “#” next to them, keep in mind these are only 13 posts out of 102. I told him around post #50 his CDI was the most likely cause of his problem. Problems helping members like the one in the link below are NOT an isolated incident.
#76, 78, 80, 83, #84, 86, #88, 93, #96, 97, #99, #100, #101
http://www.3wheelerworld.com/showthr...ht=splangeland
