On a 1984 honda 200s what voltage should come out of the alternator wires when you pull it (not when its running)? Because i get 6v out of the yellow one and nothing out of the black/red one.
Own-Honda 250es, Kawasaki kx60, Yamaha 350 warrior
Owned-one honda 350x three honda 90 s, one honda 110, one honda 185 , three honda 200e s, two honda 200s, one honda 200es, one yamaha 60, four yamaha 125 s, one yamaha 200, one yamaha 225dx , and two kawasaki 160 s, all of wich were good runing three wheelers. Also had lots of parts bikes. Also had lots of dirtbikes, 4 wheelers, gokarts, mopeds, and snowmobiles.
I forget but have a sneaking suspicion that it's AC altho any reading is better than none.
can you click on:
service manual?
It has the ohm values etc to check stator windings in general.
Someone surely knows the output you should see.
One is for lights and one is for ignition as I understand it.
Correct, the 200S is a AC only trike. There is no rectifier or regulator, the headlight and taillight bulbs act as a resistive load to the output, one bulb blows the voltage climbs the other one blows too.
If you want to measure it set a voltmeter to AC, put the red lead on the yellow wire and the black lead on the green wire, thats the lighting coil output. If you want to measure the ignition source coil output leave the black lead on the green and put the red lead on the black/red wire.
The voltage will vary, but the lighting output should be 10-20v depending on the lights being switched on, both bulbs good, etc. With the lights off, no load, you will see at least 20-30v AC on the yellow wire.
Same goes for the ignition output on the Black/Red wire, it depends on engine RPM as well. When trying to pull start it you won't see much, just a quick spike of voltage. The best way to test them in this situation is a test light so you can watch the test light pulse.
Manual is also on my server, link in sig below..
1984 Honda ATC200ES "Big Red"
1982 ATC200E "Hondie"
Thanks. But I found out I only show voltage when the wires are plunged in. That's not normal. Why is that or does it matter?
The stators are best checked via ohms and not voltage.
Most common failer on these stators is the exciter coil.
The black w/red striped wire is best checked via ohm meter. Best reading should be between 210-240 ohms. I have stated 215-240 ohms in the past ( back in 2004 ) but have found 210 -240 ohms works good.
From 2005:
http://www.3wheelerworld.com/showthr...777#post286777
From 2002:
http://www.3wheelerworld.com/showthr...=3656#post3656
Howdy
