Results 16 to 30 of 47
Thread: stop welding hubs to axle
    fcf35's Avatar
    fcf35 is offline At The Back Of The Pack Arm chair racerFirst time rider
    May 2013
    arkansas
    228
    There's a scrapyard in bradford Arkansas.the man has 2 acres of 3 and 4 wheelers.i know there's atleast 5 lt 125 there.if somebody needs stuff i go there every two weeks.
    Mar 2013
    Central PA
    2,362
    Quote Originally Posted by fcf35 View Post
    Well you dont have to brag about it now.
    We all cant be lucky and have that right in our neighborhood.
    Howdy's Avatar
    Celina, Ohio
    10,079
    I might consider this but first I have a guy coming to look at it tomorrow night. I already told him about the stripped hub / axle.
    Howdy
    fcf35's Avatar
    May 2013
    arkansas
    228
    I wasn't bragging about it im just saying that if anyone needs parts then i may ne able to get some.i only collect 3 wheelers with manual clutch so there's alot of stuff there someone else could use.
    Blossvale NY
    4,563
    Quote Originally Posted by Howdy View Post
    There are some machines where the axles are hard to find and or cost as much as the machine is worth when you do find a good one. In these cases I don't feel it's wrong to weld the hubs. I have a Suzuki LT 125 that the hub / axle is stripped almost smooth. I'm trying different things to fix it without welding, how ever I am pretty sure they will have to be welded if the machine is to be saved at all. If I weld the hub it will be just enough to hold it good and that's it.
    If you wish to call be a idiot for welding when I have no other practical choise then so be it. Yea, I found a different axle for this machine, but they want $175 + shipping. Parting the machine out is out of the question as parting it might bring $150-$175 and take 2 years to sell. Plus I already have too much invested.
    Now I have seen welded flywheels, front sprockets, shifters, brake drums, shocks, and 1 time I had one come in that had a strap welded to the gas tank to secure it to the machine. These things I do not like.
    Howdy
    That right there is the operative phrase and is what would separate an idgit from doing what you need to do to make it rideable till a reasonably priced axle can be hunted up. Big difference!
    Trikes:
    '85 ATC 350R
    '85 ATC 250R
    '86 ATC 350X
    '85 ATC 350X
    '84 ATC 200ES Big Red
    '84 ATC 125M
    '85 ATC 110
    '85 ATC 70/110
    fcf35's Avatar
    May 2013
    arkansas
    228
    Yes i should have been more specific.a few spot welds with a good welder is one thing but solid welding front and back side of each hub is overkill.that's what I was referring to.that's goes for any part.I also have a 110 that has a 3/8 wrench for a shifter.I guess desperate times call for desperate measures.
    Mar 2013
    Central PA
    2,362
    Thats a new one. Pics would be very interesting.
    Sep 2009
    moroni utah
    36
    I have ran into welded hubs once on my buddies 200s he has we were going to swap the hubs off his junk Honda fourtrax 125 so he could use the wheels and tires that were on the fourtrax but the hub was welded on kind of made us mad we couldn't jut swap the tires the wheels were different sizes and the bolt pattern was different
    I was born to ride atc
    current atc's 85 250r (the big fast one) 85 200x (old reliable go anywhere machine)
    past atc's 1970ish atc 70(still miss it) 83 110 (still miss it)
    King Trikester is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Sep 2013
    Canada, B.C, FSJ
    435
    ha, well im glad im not the only one with welded hubs, I picked up a 200es the other day and I did not realized that the hubs where welded, also the shifter and to top it off a thin pieces of plastic with what looks like super glue attempting to repair a whole in the side wall of the front tire.
    Oct 2012
    Finlayson, Minnesota
    1,066
    I don't find welding a shifter to be stupid. If the shifter shaft is stripped then it'd have to be replaced anyways. If its just the shifter thats bad then I could see that being stupid. I had to weld my shifter because the shaft was smooth all the way. I have a weld on grab bar as well.. but my frame was cut off at the back where the bar bolts to. I also have welded on foot peg, bolt was never coming out and broke off inside.
    The peg is the only thing i wish wasn't welded but then again its just a small weld nothing big.
    1985 Tri Z - Next project!
    1982 250r - Sold
    1983 Auto X - Sold
    1984 Auto X - Sold
    1985 200M - Sold
    1985 YTM 125 - Sold
    1985 185 - Sold
    1984 185 - Sold
    Check out my feedback:
    Nov 2010
    Oshawa, On, Canada
    2,123
    I consider welding anything that doesn't need to be as stupid. I could see being stranded in the trails, stripped shift shaft, and finding a house , and using their welder to get home, but as a permanent fix? No way, fix it right. Bolts can be drilled, shafts can be replaced. Axles can be found cheap, same with hubs.
    The PO of my 86R welded a grab bar to the frame. What a pain it was to grind off, and make it look untouched.
    1985 Honda 250r x2
    1986 Honda 250r
    1986 Honda 250sx
    1985 Honda 250sx x2
    1985 Honda 350x x2
    1986 Honda 350x
    1984 Honda 125m x4
    1984 Honda atc 70
    Yamaha tri zinger
    Yamaha 4 zinger
    Brap braaaap
    Sep 2011
    Ocean Beach, CA
    1,333
    jb weld head gasket, base gasket, and carb boot sealer...
    http://www.3wheelerworld.com/showthr...hlight=jb+weld
    Mar 2013
    Shamokin, PA
    36
    My shifter was wielded on...my friend bought a quad that the exhaust was wielded to the motor.
    Sep 2013
    Canada, B.C, FSJ
    435
    oh ya i forgot the jb weld on the carb intake, that would be ok for a temp fix to get you home but thats it, some peoples children these days
  15. #30
    Sep 2013
    gardners pa
    27
    never happened to me, hope it never does
