Looking for some info on putting needle bearings inside the 350x head, Mostly because i have a few heads kicking around that have the surfaces messed up and id like to save them and prevent that from happening again. I seen on one message board where you said at one time you had the cams. So figured might as well put this up and get the info out there incase anyone else needs it Thanks
