Results 1 to 11 of 11
Thread: RED HOT exhaust on 200x
    Spring, Texas
    450
    I adjusted the carb as said in the manual and started her up, and after a minute or so, the exhaust got red hot right at the head? I adjusted the carb because the the bike was not running right. It lacks power. I appreciate any helP!!
    85' 350x (newest addition)
    85' Tecate (Still dealing with electircal Issues!)
    85' Tri-Z (On the back burner)
    85' 200x (SOLD)
    Leave me Feedback: http://www.3wheelerworld.com/showthr...ack+for+ama009
    Mountain Home, AR 72653
    500
    maybe an exhaust valve leaking bye????????
    LEAN LEAN LEAN!!!!, make sure the pilot jet isn't plugged and there are no airleaks.......
    Spring, Texas
    450
    OHHHHH LEAN! damn, I kept thinking it was rich! just the opposite!! THanks Dirtcrasher!
    85' 200x (SOLD)
    Dec 2007
    Quebec,Canada
    1,014
    exhaust plugged?
    1986 ATC500X
    1985 ATC250SX
    1985 ATC200X
    1985 ATC250R
    1986 ATC250R
    1984 ATC250R
    1981 ATC70
    1984 ATC70
    1985 ATC70
    1986 ATC250SX FATCAT
    Plattsburgh, NY
    2,311
    wow thats really not good. i have witnessed this one other time. my buddy had a yamaha warrior and he got it stuck in a mud pit and he got so fed up with it that he just held it wide open til it came out. we were night riding so that head pipe was so noticeable when it was glowing bright red. it was crazy!
    E.T. "Ouch"
    TPC TRIKES
    FSU Powersports
    RNS Powdercoating
    Spring, Texas
    450
    Yea man! it was scary. I shut that sucker off immediately!
    85' 200x (SOLD)
    Wichita, Kansas
    1,361
    I'm used to my KLT200 exhaust having the slightest glow at night, but not bright like this sounds!
    Definatly sounds lean. Check the needle and the main jet also. Pilots don't normal get out far enough to make things turn red hot. Unless it's way off. No power on the bottom end or the top or the mid?
    Southern MN
    1,875
    There is also a good chance the timing is off one way or the other, by a tooth. Its an easy check to do, just to be sure.
    81, 85 Yamaha Tri Moto 125
    83 Yamaha Tri Moto 200 x2
    85 Yamaha Tri Z 250
    84 Kawasaki Tecate 250
    84 Honda ATC 70
    85 Honda ATC 350X
    84 Honda ATC 250R
    (2) 84 Honda ATC 200x
    82, 83 Honda ATC 185s
    81 ATC 200
    Lots of other parts and bikes
    Spring, Texas
    450
    No power on the low and back fires on the top end! WTF?
    85' 200x (SOLD)
    beaver bank N.S Canada
    555
    It sounds to me like these guys are right. Your timeing might be slightly off and your bike is running lean
    86TRX250R project on the go
    http://www.youtube.com/user/rocknrol...ature=mhum#p/u
    If you have an 1981 or 1982 250R feel free to join the the first gen facebook page http://www.facebook.com/#!/home.php?...938056920&ap=1
