Thread: What would be the best way to patch this up?
    Apr 2009
    Oklahoma
    1,234
    I have a welder but it's to thin even turned all the way down i still blow through any ideas?
    P.S. i tried in in an old one first...
    May 2008
    Pomeroy,PA
    86
    Whenever I weld thin material. I put a thick piece of Aluminum behind it. The weld doesn't stick to the aluminum. And absorbs the heat to prevent burn through.
    ontario
    1,131
    You can weld that no problem. You have to be very carefully though to not put alot of heat into it, the way I would do it is to just start with little tack welds around the opening and then very carefully start to fill it in with little tack welds. It would help you alot if you could get a plate be hind it to help with the heat like trikeman78 said. What kinda of welder are you going to be useing MIG , TIG,or SMAW
    1984 110 project
    1984 125 parts bike
    1983 honda 200x
    19 85x2honda 200x
    1985 honda 250sx
    1985 honda 250es
    Oct 2007
    Minneapolis mn
    4,067
    Cut the thin area back till you hit thicker metal, then patch...
    Apr 2009
    Oklahoma
    1,234
    Quote Originally Posted by hillbilly 200x View Post
    mig welder
    Nov 2010
    Oshawa, On, Canada
    2,123
    I just cut the area out, cut a piece of metal to fit, and welded it in. Must easier.
    1985 Honda 250r x2
    1986 Honda 250r
    1986 Honda 250sx
    1985 Honda 250sx x2
    1985 Honda 350x x2
    1986 Honda 350x
    1984 Honda 125m x4
    1984 Honda atc 70
    Yamaha tri zinger
    Yamaha 4 zinger
    Brap braaaap
    Connecticut
    1,605
    Quote Originally Posted by tulsamike3434 View Post
    if this is for your 110 I will see if I have that part still
