Results 1 to 8 of 8
Thread: Take a look at this trike!
    Nov 2010
    Auburn, NH
    1,061
    Trikes Currently Owned
    ~1985 Honda Big Red 250ES ATC
    ~1986 Honda 250SX ATC
    Big Mike's Avatar
    Hanson, MA
    1,062
    Kind of cool, doesnt look bad. I myself would prefer full fenders over race cuts.
    Currently Own:
    1985 ATC 250sx
    1986 ATC 350x
    Projects/Parts machines:
    1980 ATC 185S
    88 CR frame that nobody corrected the rake on when converted.
    Nov 2010
    Oshawa, On, Canada
    2,123
    I like the grab bar.
    1985 Honda 250r x2
    1986 Honda 250r
    1986 Honda 250sx
    1985 Honda 250sx x2
    1985 Honda 350x x2
    1986 Honda 350x
    1984 Honda 125m x4
    1984 Honda atc 70
    Yamaha tri zinger
    Yamaha 4 zinger
    Brap braaaap
    Jul 2012
    Douglas, Ma.
    124
    Gives it an aggressive looking stance, Hate to see that pipe get crushed, but i guess it wont see that kind of use.
    It'll hold a straight line good though so put some paddles on it and take it across the desert. or a pond.
    You say aggressive, I say incorrect.
    Right rake and stance= a bike that not only goes good straight, it can also turn. Not only that, but the bottom of the frame and pipe are not going to contact the ground if you bottom the suspension. I bet you can sit that frame right on the ground before the suspension bottoms.
    Wrong rake and "aggressive" stance= a bike that does nothing better than a properly set up bike and looks bent doing it. The "aggressive" stance is a matter of opinion, and I don't agree with it. Basically, a poorly done conversion.
    Nov 2010
    Auburn, NH
    1,061
    I agree with fabiodriven. If they went through all that trouble to make a trike, then it should be done right, but to each their own.
    Jul 2012
    Douglas, Ma.
    124
    I said it makes it look aggressive, never said it would ride correctly or that I would do it to an offroad vehicle. I've raked out a few harleys and an old GS, generally ruins the turning radius. It's hard enough to make a decent turn with a solid rear axle, nevermind with incorrect rake.
    Edit: What is the stock rake and trail on one of those?
