yeah my guess also
yeah my guess also
you may parts inside it going bad.. open it up and check it out.
3wheelers I own now: 86-ATC500R 86-KXT500 87-KXT250
Check out my 3wheeler videos on youTube Lazybiker79
http://www.youtube.com/watch?v=UNy9k...qljTifaAX47-6w
But it's not a huge difference, and if you ride in any kind of wet conditions at all it's not worth the trouble. Engines don't like their fuel/air mix with a shot of water.... Great for dunes and dry condtitions though!
What I have done is kind of a blend of both approaches.... I removed the snorkel pipe that connects the airbox to the main frame backbone. While it does pose a little more risk of water ingestion, it does open up the airflow alot while providing most of the protection of running the full airbox. Had to jet up 2 sizes when I removed that snorkel pipe.
That might be a better alternative for you if you want better airflow without running a full airbox eliminator setup.
Trikes:
'85 ATC 350R
'85 ATC 250R
'86 ATC 350X
'85 ATC 350X
'84 ATC 200ES Big Red
'84 ATC 125M
'85 ATC 110
'85 ATC 70/110
really? i didnt know that i thought the engine just breathes beter...but it would efect jetting right
i oiled it and it was better but still a little hard
Did you lube the cable?
plug chops
NO check youtube..
yes i did cable is fine
Really not hard at all if you are mechanically able.
We are glad to help here at 3WW, but some topics have been covered quite thoroughly and a little time searching certain topics (like fork rebuilding) should net you plenty of results. Give it a try and check back.
Trikes:
'85 ATC 350R
'85 ATC 250R
'86 ATC 350X
'85 ATC 350X
'84 ATC 125M
'85 ATC 110
'85 ATC 70/110
yes ride it wo then check it
no? what does that mean
