Results 1 to 12 of 12
Thread: New ride: 1984 Yamaha YTM225DXL, farmer find $200!
    Jun 2014
    KS
    33
    Hey gang,
    Getting close to full access to the site, yeeha!
    Here is the 84 225DX I just picked up. Got this trike and a matching donor for $200 from a local farmer. His dad bought it new here where we live and it came with the original owners guide and certificate of origin from 1984! The guy I got it from had the camshaft seize in the head so he bought the other one (complete minus plastics) and swapped over the head and he never got it running after he did the work years ago. Major carb cleaning and minor timing adjustment and she took right off! EVERYTHING works: front and rear brakes from foot and hand controls, electric start, headlight high/low beams, taillight, original owner added horn and the custom made trailer hitch and cargo rack, the aftermarket straight open exhaust sounds awesome. The only thing it needed was a throttle cable, $15 ebay buy later and its all good to go!
    Trying to decide if i'm going to flip it and take the cash or just keep it and ride the heck out of it. If only it wasn't yellow...yuck! I have a ton of good parts on that companion parts trike too if a guy was gonna keep it...Super fun ride with a surprising amount of power, pulls the front wheel in 2nd gear without even trying!
    The only issue I have found is its very noisy at idle behind the RH engine cover, down low so I'm figuring its a clutch issue? Shifts fine, doesn't slip, using a stethoscope it doesn't sound like anything is contacting the case. Any ideas or known issue help is greatly appreciated!!!
ID:	199882   Click image for larger version.
ID:	199885   Click image for larger version.
ID:	199886   Click image for larger version.
ID:	199883   Click image for larger version.
ID:	199884   Click image for larger version.
    YamaBoss's Avatar
    YamaBoss is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Aug 2014
    Minnesota
    251
    Wow, lucky man!! Nice find
    Mar 2014
    New Brunswick, Canada
    147
    Great find for 200. Really. Is there shavings in the oil.
    Jun 2014
    KS
    33
    Quote Originally Posted by rdonald1979 View Post
    When I first got it and changed the oil both the screen behind the oil plug and the filter were clogged and there was a significant amount of shavings in the oil. That is why the original cam seized in the head I'm sure. I rode it quite a bit this weekend and plan on changing the oil again to see if there's more. Does seem to slip a little bit before fully engaging first gear, but other than that it ran like a top. I did adjust the clutch per the shop manual as well before riding....
    Nov 2013
    Oxford CT, New Haven County
    984
    REALLY SWEET DEAL! you got lucky. I gotta make me a trailer hitch for mine, at least if I can pull the garden cart, ill have more chances to actually ride the damn thing... lol
    Nov 2013
    984
    Quote Originally Posted by czac View Post
    hell, maybe I l find some sort of lawn mower I can pull around and cut the grass with it too....lol maybe other garden / yard attachments...
    YamaBoss's Avatar
    Aug 2014
    Minnesota
    251
    http://instagram.com/p/p4s_6YBdVu/
    Check that out. That's what you wanted right?
    Nov 2013
    984
    Quote Originally Posted by YamaBoss View Post
    shoot, I already got that...lol I guess I could just tow the tractor around in neutral with the cutters engaged! lol...
    Jan 2014
    North Bend, OR
    42
    Great find, we have 2 of them, 85's most reliable bike we've owned
    ATC 70
    ATC 110
    Yamaha 225DX
    ATC 185s
    86 ATC 310r
    Jun 2014
    KS
    33
    I ran the first oil change for less than 10 hours and changed it, both the drain plug screen and filter were once again full of metal shavings. I figure I'm gonna have to dig in to the clutch setup and find out what is rubbing where. Good news is I have another complete bottom end if needed...
ID:	202943Click image for larger version.
ID:	202944Click image for larger version.
ID:	202945Click image for larger version.
    Aug 2014
    Orange, Texas
    36
    Boy that doesn't look healthy at all !!!!!
    glendive, montana
    1,822
    Check with a magnet to see if it's steel or if its aluminum. I have a feeling you're looking at a complete tear down and rebuild on that soon. I would also check the compression and see if its low.
