Results 1 to 15 of 18
Thread: HELP how to clean a old steel gas tank.
    Aug 2014
    Quebec
    51
    someone have tips or advice to clean my old and little rusty inside steel gas tank .i shake it and i heards some rust and sand inside ...i throw air inside and try a vaccum whit carpet cleaner but still. many little dust inside.thanks
    Oct 2013
    Wherever I May Roam
    3,757
    Fill it with Apple cider vinegar and let it sit at least overnight. If you aren't concerned with the paint you can have it hot tanked.
    Honda used to sell a product that would make any tank look new, but alas like all good things they quit selling it.
    glendive, montana
    1,822
    I second the apple cider vinegar, I have used muriatic acid and prefer the vinegar, it just works better for me I leave it for a couple of days.
    f76's Avatar
    f76 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Jun 2014
    South Dakota
    323
    Like the others said, cider vinegar for at least a couple days. Then dump in a bunch of small nuts and bolts or other small metallic objects with corners and shake the whole thing around for as long as you want. Then rinse with vinegar and blow it out. You can then buy a good inner tank coating or use wd-40 to help prevent rust.
    85 Kawasaki KLT 160
    85 Kawasaki KLT 110
    82 ATC 70
    2000 Scrambler 500
    May 2013
    Brownsville, Tn.
    1,271
    Navel Jelly.
    * Nicholson 500 Race Bike *
    kaymo is offline At The Back Of The Pack Arm chair racerFirst time rider
    Feb 2013
    Hickory NC
    191
    ive used muratic acid. tried vinegar but dont it was white and didnt do much. the acid eats a lot if you leave it too long!
    MPDano's Avatar
    MPDano is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Sep 2014
    I used Por 15 in my Honda Odyssey tank and it works exactly as promised. A little pricey but the end result is the tank will "never" rust again. It even sealed up tiny pin holes too.
    http://www.por15.com/POR-15-Motorcyc...it-_p_106.html
    Sep 2014
    NO Ohio
    18
    I just did my first gas tank cleaning the other day. I went with muriatic acid. Used a gallon plus enough water to top off the tank. Let it sit about 2 hours and 15 years of rust from being stored empty is long gone. Looks brand new inside. I drained the acid into a bucket. Then mixed up some water with a bunch of baking soda and rinsed the tank with that a few times. Then washed the inside wi th soap n water. Rinsed a few times and let it dry out in the sun.
    I don't know that it's the best way to do it, but I had the acid on hand for the pool and it did a great job.
    Just use caution. Muriatic acid is not weak just because you can get it at the hardware store. I wear gloves and goggles. At the bare minimum, keep the hose nearby incase you splash some on your skin or the paint job.
    Aug 2014
    Quebec
    51
    i bought some apple cidder vinager...i will talk about result soon.but i found 2 little leak ...what i can use to fix to little hole .i think i will use some cold weld.
    glendive, montana
    1,822
    cream, redkoat, or por 15 work for fuel tanks, jb weld is really only a temporary fix I have found. It always cracks over time on me with fuel tanks.
    cap's Avatar
    cap is offline At The Back Of The Pack Arm chair racerFirst time rider
    Jan 2014
    Nevada
    163
    Quote Originally Posted by freak trike View Post
    Redcoat will fill small pinhole leaks.
    Oct 2013
    Wherever I May Roam
    3,757
    The absolute best way to fix pinholes in most honda tanks is to find another tank. Every solution is temporary.
    Dec 2010
    South Georgia
    15
    I have used MEK. There a few videos on electrloysis and a battery charger on youtube with a sacrifical rod to collect the rust. I have never tried. I also have never had any luck with JB Weld but a buddy of mine smuggles Belzona out of the plant where he works. That stuff is amazing. I have patched tanks, sheet metal, etc.. and never had a problem. Im sure it can be purchased somewhere.
    Aug 2014
    Boiling Springs, Pa
    9
    I did the contractor sand and distilled water method. Wish I knew about the previously noted methods as the sand was a pain to completely flush out. Also have filters on the lines for any sand that refused to rinse out.
    May 2013
    Brownsville, Tn.
    1,271
    Navel Jelly....
