Page 7 of 8 FirstFirst ... 5 6 7 8 LastLast
Results 91 to 105 of 113
Thread: Built from scratch: 250R
  1. #91
    Aug 2015
    Germany, Bavaria
    98
    I procastinated the next step the whole project but one day it needed to be started... the seat:
ID:	222413Click image for larger version.
ID:	222414Click image for larger version.
ID:	222415Click image for larger version.
ID:	222416Click image for larger version.
ID:	222417Click image for larger version.
  2. #92
    Aug 2015
    Germany, Bavaria
    98
    I had no aluminum tube with that large diameter to built the intake adapter for my carb so i rolled one:
ID:	222419Click image for larger version.
ID:	222420Click image for larger version.
ID:	222421Click image for larger version.
ID:	222422Click image for larger version.
  3. #93
    Aug 2015
    Germany, Bavaria
    98
    I won some hubs on ebay:
    during my first test ride i burned my leg... thats somthing only carbon can fix:
ID:	222425Click image for larger version.
ID:	222426Click image for larger version.
ID:	222427Click image for larger version.
ID:	222428Click image for larger version.
ID:	222429Click image for larger version.
  4. #94
    Aug 2015
    Northern Maine
    17
    WOW!!! Simply amazing, now put some in production and I will buy one!!!
  5. #95
    Aug 2015
    Germany, Bavaria
    98
    Quote Originally Posted by strykerlover View Post
    Just in case, how much would you pay?
  6. #96
    Aug 2015
    Northern Maine
    17
    I'd pay $6000 but that's because I'm poor! LOL! If I had money I'd probably spend up to $8000 for that!!! I know it's worth more than that!
  7. #97
    Aug 2015
    Germany, Bavaria
    98
    Hi everyone,
    sorry for letting you wait...
    Some pics from the last days of manifacturing:
    Time to give the seat some fur...
ID:	223737Click image for larger version.
ID:	223738Click image for larger version.
ID:	223739Click image for larger version.
ID:	223740Click image for larger version.
ID:	223741Click image for larger version.
    That is some kind of rubber foam that straightens the surface and fills up some holes from the grinding of the base material.
  8. #98
    Aug 2015
    Germany, Bavaria
    98
    Preparation of the aluminum sheets which hold the leather:
    Time to put on the leather:
ID:	223744Click image for larger version.
    It is partly riveted and the positions where it was not possible i glued it with kövulfix, a strange contact glue that is normaly used to glue shoes. You have to apply it, let it dry for 10 minutes and then you have to push everything together, the stronger you push the stronger it glues togehter.
    Till now it works great.
ID:	223746Click image for larger version.
  9. #99
    Aug 2015
    Germany, Bavaria
    98
    Last remaining parts were painted red:
    The kickstarter is held by a HDD magnet:
ID:	223749Click image for larger version.
ID:	223750Click image for larger version.
  10. #100
    Aug 2015
    Germany, Bavaria
    98
    Almost done, time for a new project:
ID:	223752Click image for larger version.
    Cause engine came from a CR it is kicked backwards and i needed to cut the fender. That puzzeld me for a week to find a solution that is not to ugly:
ID:	223754Click image for larger version.
ID:	223755Click image for larger version.
  11. #101
    Aug 2015
    Germany, Bavaria
    98
    everything was stiched together with cable ties:
    Result after the first debug run:
    One of the brake bolts vibrated itself loose and the brakedisc cutted trough the bolts of the caliper, that was fixed and some loctite should now do the job...
  12. #102
    Aug 2015
    Germany, Bavaria
    98
    some footage of the finished trike:
ID:	223764Click image for larger version.
ID:	223765Click image for larger version.
ID:	223766Click image for larger version.
ID:	223767Click image for larger version.
ID:	223768Click image for larger version.
    Everything works now great, it hawls asses and has an unusal power at low rpm but also a strong powerband when you speed it up.
    The only disadvantage is the unusual position of the right leg because of the large pipe, but this is a point that i can accept
    It now needs a bigger chainwheel to use the last two gears too...
    Next i will write report of my Kawasaki Mocate built if you are interested ?!
  13. #103
    The Open Road
    4,736
    Great build!!
    Yes, I would like to hear about the Mocate build too.
    Sent from my Z998 using Tapatalk
  14. #104
    Jan 2015
    Rock Valley Iowa
    35
    Sticker_saap, what size, and kind are those tires on your three wheeler.
  15. #105
    Surprise, AZ
    2,428
    Mocate, please
