Results 1 to 11 of 11
Thread: Battery charger
    ArizonaATC is offline At The Back Of The Pack Arm chair racerFirst time rider
    Nov 2012
    Eastern Canada
    163
    Battery charger
    hello guys so i hooked up my battery charger (2A) to my trike battery and it isnt charging, the light that says charged is only coming on, which it isnt because it wont even move the starter, whats my problem? thanks again guys!
    Aug 2015
    Idaho
    843
    Quote Originally Posted by ArizonaATC View Post
    Could be bad battery. They don't like to be drained and charged constantly. Need to maintain a full charge.
    Nov 2012
    Eastern Canada
    163
    Quote Originally Posted by Jd110 View Post
    i suppose! but wouldnt it still atleast try to recharge? the light that say charging on the charger isnt even coming on! and the battery would take a charge after 30 min of riding 2 weeks ago and it would hold enough of a charge to use the starter. if i do need a battery what would be the best bang for my buck for a good battery
    Aug 2015
    Swisher, IA
    92
    Is it a wet or dry cell battery?
    "You see, in this world there's two kinds of people, my friend. Those with loaded guns and those who dig. You dig."
    Trikes Owned:
    1986 Honda 250r
    1985 Honda 200x
    1985 Honda 200m
    1984 Honda 200es
    1983 Honda 200x
    1983 Yamaha Tri-Moto 200
    Nov 2012
    Eastern Canada
    163
    Quote Originally Posted by apickering975 View Post
    its a wet cell
    Nov 2012
    Eastern Canada
    163
    its a wet cell
    update: its not saying its charging but it is a little, unhooked the charger and the headlight would come on dim and the starter buzzed but wasnt strong enough to rotate, this was after almost 1 hour so il leave it on for 6 or so and see what happens.
    also jeez 3 wheeler world be loggin me out after 3 min of tardiness like its a bank website
    Aug 2015
    Swisher, IA
    92
    How old is the battery? You could try changing the fluid in your battery. If that doesnt help I'd buy a new battery for it. It will be worth it in the long run.
    Trikes Owned:
    1986 Honda 250r
    1985 Honda 200x
    1985 Honda 200m
    1984 Honda 200es
    1983 Honda 200x
    Nov 2012
    Eastern Canada
    163
    i couldnt tell you, bought the trike about 2 months ago, but if this dosnt work i will be getting a new battery
    May 2009
    S.E. Michigan
    1,251
    If you need to get a new one, get a sealed battery. I've had better luck with them compared to the conventional batteries that are vented. Also, unless you ride in the winter, remove it from the machine in the winter and keep it inside and on a battery buddy (or any other battery tender). It will last you a long time this way. Even if you can't remove it, keeping it topped off on a battery buddy while you don't ride it will keep the battery in great shape.
    - Frank
    1984 200ES Big Red
    1985 350X (x2)
    1986 350X
    1986 250SX
    1984 Auto-X
    1984 ATC70
    1985 ATC70
    devore,ca
    1,044
    2 amp charger might be a bit much. Most motorcycle battery chargers are under 1 amp. A 2 amp would be more for a lawn tractor or a side x side. The small motorcycle batteries won't take much abuse at all.
    YAMAHA 450 HYBRID
    85 350X- RED
    85 350x -BLACK
    86 350x-WHITE (with Goki)
    85 250r
    83 atc 70
    84 atc 70
    84 atc 110
    09 yfz 450
    2006 Arctic Cat Prowler
    RZR XP 900
    Tionesta, PA
    5,747
    you need a new battery. Plain and simple!
