Results 1 to 15 of 19
Thread: 86 250r clutch cable woes
    Sep 2008
    Buffalo
    808
    I don't know what the heck is going on but I can't get a stinkin clutch cable to adjust on my 86 250r. The cable the bike had on it broke, so I tossed it and ordered a new motion pro cable that is suppose to be to Oem specs. I put the cable on but it wouldn't adjust right. I was maxed out on the lever adjustment and at the clutch arm and I still needed more pull. So I assumed they sent me the wrong cable, or that they just didn't have the specs right. So I get an "Oem" cable off eBay to see if it would be different, and wouldn't ya know it's the same as the other one. Looks kinda new too. So now I doubt it's from 86. So what gives? Why are these cables maxed out on both ends? They are close to working but I need more adjustment, there's no way I should be maxed out on both ends and it just barely works. Im about ready to modify the clutch cable bracket to give more adjustment, which should work, but I'd rather just get the right cable. Can anyone measure a stock cable? Or have one to sell? Or lead me in the right direction. I've tried a few other cables I had kicking around but nothing is right. I'm getting sick of this cable shenanigans, help me out.
    Tpc 450
    86 250r
    86 350x
    86 200x
    86 250sx
    85 225DR
    (2) 84 YTM
    (3) 85 Atc 70
    Slidell, LA
    4,738
    I gave up on motion pro a long time ago concerning cables. Their tolerances are so out of whack it's not funny. Go to partzilla and get a OEM cable
    House Springs MO
    5,494
    Motion Pro clutch cables suck. I've never had one of those cables adjust properly. OEM is the only way to go.
    Sep 2008
    Buffalo
    808
    I'm on partzilla but don't see Oem cable. I read elsewhere it's been discontinued. Is that true? Trying to find an Oem cable on eBay, even used, cause I'm pretty sure I have two motion pro cables at this point. Send a link if you have a chance I can't find anything but aftermarket
    Tpc 450
    86 250r
    86 350x
    86 200x
    86 250sx
    85 225DR
    (2) 84 YTM
    (3) 85 Atc 70
    Onetrackmind's Avatar
    Onetrackmind is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Jan 2015
    Allen Texas
    399
    I had the same problem w my 85. The Motion Pro I ordered did not work at all. I lucked out and found an OEM by having my local Honda shop do a dealer locator search...try that.
    If that doesn't work out, try using a spacer (washers or another nut) on the clutch cable mount.
    Slidell, LA
    4,738
    Quote Originally Posted by ATCeeya View Post
    Well that sucks. They were available a year ago. Like Onetrackmind said, get the part number and call a Honda dealer and ask if they have the national database search. I know a dealer somewhere has one collecting dust on a shelf.
    House Springs MO
    5,494
    I'm glad I've got a few oem cables stashed away.
    Sent from my SM-G900V using Tapatalk
    Jul 2011
    Colorado
    141
    Ceeya,
    Are you using a wider than stock handlebar? Try moving the clutch perch toward the center a half inch.
    I use Pro Taper mid-ATV bars and this is an issue with OEM and MotionPro cables. I have to fudge both the throttle perch and clutch perch placement.
    Jan 2013
    minnesota
    5,911
    Incredibly simple fix . Simply have the inner cable shortened to the proper length and a new end installed.
    PREVIOUS KAWASAKI INTERNATIONAL R & D PROJECT ENGINEER AND ATV DEPARTMENT SUPERVISOR
    6,797
    Time to do an 89 clutch upgrade kit . This will give you full adjustment on your clutch cable . Very common problem with the 250r when theirs no adjustment left in your cable . Your factory parts are worn out . Pull the actuator arm out and inspect that for wear as well .
    Jan 2013
    minnesota
    5,911
    Yes it has been discontinued, however, the place below says they have one left and their inventory is fairly accurate . The price is in Euros so it is actually $25.24 usd plus shipping . They are the biggest NOS motorcycle and atv parts stocking place in the world.
    http://www.cmsnl.com/honda-atc250r-1...2.html#results
    Here's a few used ones on Ebay.
    http://www.ebay.com/itm/like/2719804...&ul_noapp=true
    Hell, you can even have one made . I was fixing cable ends and making all new cables as far back as 1975 . It's not too hard to do.
    Kryten's Avatar
    Kryten is offline At The Back Of The Pack Arm chair racerFirst time rider
    St. Louis, MO
    157
    I agree on the '89 clutch upgrade kit, I tried Motion Pro and OEM clutch cables for my '85, but both would not work. The clutch upgrade is what I needed to replace severely worn parts and allow cable adjustment like you should have.
    1984 ATC200S
    1984 ATC200X
    1984 ATC200M
    1985 ATC200X
    1985 ATC350X
    1985 ATC250R
    1986 ATC200X
    1987 ATC250SX
    TPC450
    Sep 2008
    Buffalo
    808
    That would definately do it, not sure where to get that done though. I ordered that cable off that website. The shipping cost more than the cable lol. Problem with eBay sellers is they say it's Oem and it's not. The "Oem" cable I just bought from there is another motion pro if I had to guess. We'll see what the one from that website shows up looking like, I'll check into the 89 upgrade kit in the meantime. I just want to get it sorted out and ride the dang thing again.
    Tpc 450
    86 250r
    86 350x
    86 200x
    86 250sx
    85 225DR
    (2) 84 YTM
    (3) 85 Atc 70
    arlaunch's Avatar
    arlaunch is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Jun 2014
    Oregon City
    346
    I have a motion pro clutch cable and have no problems? Also a motion pro thumb throttle cable. Works great! Without them a lot of people would be parked.
    The only real way to know it the cable is incorrect and why, is to measure the thing. Maybe one of the nice fellas with an unused OEM one could measure it and post the results?
    I went with a Wiseco basket and Honda OEM plates and the 89 clutch update. Lots of money to go back to were you started from. Then your bike is worth $50 more on craigslist LoL.
    If the ball on the original clutch is not welded, I would not do the clutch update. But... If you are replacing a part, it is a little nicer on the hand. It does not make you go faster though.
    1984 Honda Big Red ATC 200ES (Emma)
    1985 Honda 200X ATC (Pretty Boy)
    1985 Honda 250R ATC (Dr. Fast)
    1985 Honda 250R ATC ( 77 )
    1985 Honda 250R ATC (Baller)
    1986 Honda 350X ATC (Go Go Girl)
    Feed Back: http://www.3wheelerworld.com/showthr...k-for-arlaunch
    House Springs MO
    5,494
    Quote Originally Posted by arlaunch View Post
    Motion pro throttle cables have been great for me, but the clutch cables not so much. I put a new motion pro on my 250r when I rebuilt it. New everything including nos oem clutch lever and perch, oem handle bars, new take out actuator arm, 89 update with new oem basket, and clutch. I ordered a new oem cable and never had an issue. My tecate motion pro cable required max adjustment along with my kx250. I put an oem on my 02 kx and it worked like a champ. But, the throttle cables have been great. I have a nos oem 250r cable I have to find that I'll measure.
