Thread: 10.25:1 piston in pull start engine...Can I pull it?
    Dec 2015
    Port Robinson
    7
    Putting together a 200s engine out of spare parts . Have a 200x jug with 10.25:1 wiseco . Will this be hard to pullstart ?
    The Open Road
    4,736
    Quote Originally Posted by Tim Hall View Post
    Probably. It will especially be hard on the pull cord.
    Doesn't the 200S have a compression release in the valve cover? I'm pretty sure it does so use that cover with the 200X stuff and you might be fine
    125Mmadness's Avatar
    125Mmadness is offline At The Back Of The Pack Arm chair racerFirst time rider
    Apr 2017
    McConnelsville,Oh
    157
    It's not all that bad for me but, then again I have a big cam with a lot of duration and that will take some comp. away but I still think it would be doable with a stock cam.
    1985 ATC125M: Parts
    1985 ATC200S: 84 200S Bottem end, 200x Head, 200x Carb, S&S Cycle Exhaust, Wiseco 10.25:1 Piston, Reground Cam with About 1mm more lift(unknown specs).
    1988 TRX250X
    1983 ATC200E: Total Pile.
    "Bout Tree Fiddy" Master of Thy 22RE
    Slidell, LA
    4,738
    No it won't. I had a 200s with a 12:1 piston. That puppy broke ropes left and right.
    Dec 2015
    Port Robinson
    7
    Thanks for the replies
