Dennis Kirk has them for $37.99 but I found that I can get them cheaper at the local autoparts since I get a good discount. You could try Autozone too since they carry K&N.
Lots O Trikes!!!!!
TRIKEFEST 03, 04, 05, 07, 09 Going the distance
Damn, that engine is pretty nasty looking. If you had the right kit for the 90, you could go 124 and still have room left. If you had the opening of the engine cases machined out, you could drop in a 110 clyinder and head. IF you really opened up the engine cases, you could resleeve your cylinder and run a cb750 piston with a little work to the piston skirt and weight balancing and still have room left! How far do you want to go?
good stuff edog. looks like your taking your time and doing it properly.
wanted.. 84 atc70 fuel tank
My old 1985 250R http://www.flickr.com/photos/24898661@N07/show/
Feedback http://www.3wheelerworldforums.com/s...feed+back+edog
Currently trikeless
1986 ATC 70
1985 ATC 250R - Hondaline Special
1985 ATC 250R - Flat Track 'Privateer'
1985 ATC 250R - HRC 450RR.
1986 ATC 250R - HRC Flat Track.
1998 Honda Laegers TRX 250R (CT 350 PV) N/F cr500 link.
1998 Honda Laegers TRX 250R (Sparks 330) N/F cr500 link.
1999 Honda Laegers TRX 250R (Sparks 330) N/F cr500 link.
2016 Yamaha Laeger's Banshee YFZ 350 (DRI 350) N/F cr500 link.
Nah they're not bent, those were precission modifited for increased steering rake!
Currently trikeless
1986 ATC 70
edog, the lifans are patterned after the atc70 engines. The atc70 engines are smaller than the atc90 engines. All the bolt holes will not line up. You will have to make some mods.
Currently trikeless
Couldn't you just post a link to the engine. Why do you have to liter the forum with a MILLION pictures. I'm on high speed and the site loads so freaking slow when ever I get in one of your threads or if YOU get in someone else's thread.
Be considerate and cut your picture size down. You're making the site less fun for other people. If you need a side to side scroll bar on a standard 1024 X 768 screen its being inconsiderate.
Currently trikeless
You're not funny. Now you're being an ass.
I agree Louis.. Its a big PITA (sorry edoggy) but this thread and the summertime pic thread in trikesylvania are to that come to mind right away.![]()
I get lost trying to scroll up and down,, side to side.. etc. and even tho I'm on dsl it still takes a while.
Just because you have a large moniter and it maybe centered for you.. it doesn't mean the rest of us do.![]()
at least he's cutting back on the you tube links tho...![]()
