Page 3 of 5 FirstFirst 1 2 3 4 5 LastLast
Results 31 to 45 of 75
Thread: I now own an 82 250R!! [Updated with Pics!!]
  1. #31
    edog's Avatar
    Mar 2004
    New Hampshire
    6,629
    Quote Originally Posted by Saul View Post
    It is a lil bit bent at the bolt. I'm guessing a new bolt will fix the prob?
    Maybe the frame.
  2. #32
    Andrew_250R's Avatar
    Andrew_250R is offline At The Back Of The Pack Arm chair racerFirst time rider
    Jul 2008
    New Salem, ND
    157
    You acutally use the swingarm bolt to adjust the chain tension. So maybe the bolt is just crooked and needs to be adjusted right? If not there is a swingarm bolt forsale in the classifieds, it is from an 82 but it should be the same.
    81' Honda 250R ( FOR SALE )
    85' Honda 250R ( FOR SALE )
  3. #33
    Internet
    1,251
    Quote Originally Posted by Andrew_250R View Post
    My trike is an 82.
    I'm such a noob right now concerning these trikes. *sigh* I'll be asking some pretty retarded questions I'm sure.
    Here is one - can the fenders and seat and maybe gas tank from say 84-85 R's be retrofitted onto an 82?
    Another - why does extending the swingarm on these bikes make them handle like *Edited**Edited**Edited**Edited* but extending swingarms on 84-85's make them handle better?
    One more - can I mount some lower profile handlebars on this trike? What will work?
    Thank god I have some knowledgable trike-heads on here to help!
    What's a better shock I can run out back? Brand names and links?
    Someone mentioned running a front end/shocks from an 84-85 up front - will that just bolt right on?
    Thanks in advance guys.
  4. #34
    Jul 2008
    New Salem, ND
    157
    My trike is an 82.
    I see, not sure why I thought it was an 81'. I would still check the swingarm bolt to make sure it is adjusted straight. It doesn't really look like the frame is bent seeings how the swing arm is not even inline with the gastank.
  5. #35
    Yamatrike400's Avatar
    Yamatrike400 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Jan 2008
    MINNESOTA
    393
    My trike is an 82.
    I dont think it made it handle like crap, it made it better if anything. Yes you can buy bars from dealers etc...look on ebay for MOOSE bars. there cheap. If u extend the swingarm, use a longer sled front shock off a newer sled. i used one off a 2005 polaris classic and it works great. I know a 200x front end will bolt right on (triples, forks, hub, wheel)
    Three Air R's
  6. #36
    Internet
    1,251
    Yeah, I'm hoping that tomorrow I'll have a good full day to look the bike all over and check things out much better.
  7. #37
    Internet
    1,251
    Quote Originally Posted by Yamatrike400 View Post
    Thanks for the info on handlebars and front end and swingarm - it just seems like I'm getting conflicting stories on the swingarm extension.
    Time to scour ebay for 200x front end maybe? If I run a 250 front end I'll have better shocks up front and can run a bigger front rim right?
    Also, my rear rims are 3 bolt rims - is this the correct stock rim thats spose to be on there?
  8. #38
    NE Indiana
    1,067
    You can help handling with an extended swinger of maybe 2" but when you start going 4" and more you will lose handling. I wider axle is the way to improve handling. The main reason people use swingers that are extended way out to 4" or more is because they have highly modded engines and it helps the weight distribution to keep the front end down better. It also helps with hillclimbers. So mainly drag racers and sand/hillclimbers with big power engines use extremly extended swingers. if you're going to trail ride and just have some general fun, stay away from 4" or more swingers. Go with 2". Then get a wider axle or some wheel spacers. Also, smaller square tires instead of those balloons would help too. Like the Fast trekkers.
  9. #39
    Internet
    1,251
    Thanks for that Hoosier.
    In the end I'll probably extend the swingarm 2-3 inches (if any) but I for sure wanna go with either a wider axel or spacers. So what kinda spacers should I be looking for? What about hubs from other bikes?
  10. #40
    Jul 2008
    New Salem, ND
    157
    The stock rims on the 81'R are two piece three bolts, so I assume the 82' also had two piece three bolt rims.
  11. #41
    Internet
    1,251
    Well I know that I wanna get some better rims and tires on mine asap. Just gotta wrap my head around what is involved in swapping out parts needed to make it work.
    I 'think' a new front end, from say a 200 X will fix the front and then I need new hubs for the back?
  12. #42
    Internet
    1,251
    So - today I got the muffler back on her with the help of some ole good ole exhaust flex hose!! Got my foot shift lever welded by a friend and got a 30 minute 'hands-on' ride. WOW! These things are fast huh?!
    I didn't have a good long stretch to open her up past 4rth gear (no brakes on the bike right now) but from 1st to 4th was sick. She can hang out the front tire like nobodies buisness. Very much an eye opening experience for me.
    Quick question - what kinda plug does these bikes call for stock? Whats a good 'upgrade' spark plug?
    Thanks in advance.
  13. #43
    Jul 2008
    New Salem, ND
    157
    I run either a NGK BR8ES or a BR8ES. The BR9ES is colder I believe.
  14. #44
    Internet
    1,251
    Closest I can find is a champion RN3C - I'll make do with it for now.
  15. #45
    Jul 2008
    New Salem, ND
    157
