Page 3 of 5 FirstFirst 1 2 3 4 5 LastLast
Results 31 to 45 of 62
Thread: Adjusted valves....STILL ticks
  1. #31
    Holland, NY
    635
    Well Mike just pointed out that I have an auto cam chain adjuster..........SO looks like itll NEED to be torn down just to do the cam chain so Im probobly gonna do a top end rebuild...Is there a kit to do this with all gaskets, seals, parts?
    TRIKES:
    1985 Yamaha YTM 225 DR Special Edition
    Dirt Bikes:
    2006 Honda CRF 250R
    SLEDS:
    2001 Ski Doo MXZ 600
    1997 Ski Doo MXZ 583
  2. #32
    Sep 2008
    845 New York
    2,302
    dennis kirk has the gaskets for the top end ,piston/ring idk bout seals though..also im sure egay has everything
    1985 Quad Killer
    1985 Mini Raag
    1985 Green Gobbin X2!!
    1990 Kawasaki 300sx
    R.I.P
  3. #33
    Apr 2006
    Crestview, Florida
    2,429
    You say it smokes? Maybe its piston slap?
    Rides
    85 ATC350X
    85 ATC200X
  4. #34
    Holland, NY
    635
    What causes a piston slap? How do tell how big my current bore is?
    TRIKES:
    Dirt Bikes:
    2006 Honda CRF 250R
    SLEDS:
  5. #35
    Apr 2006
    Crestview, Florida
    2,429
    A topend thats worn enough will make piston slap. Its exactly what it sounds like, the piston slaping around in the cylinder.
    I would also do the cam chain as everyone else said. It would suck to install a new piston kit and have to tear it back apart for the chain.
    You can in most cases pull the head and find marking or numbers on top of the piston to tell the current bore size. You will need a over sized bore piston kit. I'd pull the cylinder and take it to a local machine shop and have them look at it to find the current size and what size kit you need.
    Rides
    85 ATC350X
    85 ATC200X
  6. #36
    85Tecate is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Mar 2009
    Iowa
    442
    Quote Originally Posted by Erics350x View Post
    I agree 100%. If it IS piston slap that cylinder is going to need bored.
  7. #37
    Holland, NY
    635
    How can you tell if the piston slapped? Is the cylinder all scrattched up. Im definately gonna do a ring/valve/chain job over the winter just need to get some cash amd need more garage space lol
    TRIKES:
    Dirt Bikes:
    2006 Honda CRF 250R
    SLEDS:
  8. #38
    Oct 2009
    Seneca, Pennsylvania
    91
    I would say it is the timing chain I had the same problem on a 400 ex.
  9. #39
    Milkman took the words out of my mouth.
    These old machines need timing chains AND sometimes tensioners.
    I'm not educated on a Yamaha auto or manual tensioners, but they just hold something in place. They DON'T do much work, but the timing chain and gears sure do.....
    I must admit, I almost never find worn TC gears, just a worn and stretched chain from doing it's job for 25 years.....
  10. #40
    Holland, NY
    635
    Quote Originally Posted by 85Tecate View Post
    Those are philips head screws if i remember correctly arent they? The way i try to get those out when theyre siezed is to hit the handle of the screw driver as im trying to loosen the screw. Sometimes works, sometimes doesnt. They make a nice tool specially for stubborn screws like that. You actually put it on the screw and smack the end of the tool with a and it turns it when you hit it.
    Here is what im talking about. They work incredibly good... http://www.harborfreight.com/cpi/cta...emnumber=37530
    Ok time for an update...I went and got the impact screwdriver 85Tecate was talking about and got the cam cover off. One snapped halfway off so ill have to drill and tap that one not a big deal. So I was wondering how to tell the cam chain is too loose it feels pretty snug with some pay but it doent fell terrible. is it supposed to be tight
    TRIKES:
    Dirt Bikes:
    2006 Honda CRF 250R
    SLEDS:
  11. #41
    Mar 2007
    Texas
    5,045
    order an impact screwdriver set from sears not harbor freight. thise HF ones snap the tip soff easly. the craftsman will last you for years!! I've used mine a ton on trike rebuilding and brake jobs. so that's really your best bet.
    ________________
    https://www.mikesatvfix.com
  12. #42
    Mar 2007
    Texas
    5,045
    Quote Originally Posted by Kerick View Post
    there should not be any play in it. it't not a timing belt that has a tiny bit of play. it's a chain and should have no play.
    se if you can adjust it to quiet it down, if not, time for a top end rebuild.
    ________________
  13. #43
    Holland, NY
    635
    Quote Originally Posted by oscarmayer View Post
    So it should be totally tight?
    TRIKES:
    Dirt Bikes:
    2006 Honda CRF 250R
    SLEDS:
  14. #44
    Mar 2009
    Iowa
    442
    Yes, no play at all. The problem with just adjusting it to take the noise out is, even though it may very well adjust to take the noise out, the timing will be off because the chain is stretched.
    1985 Kawasaki Tecate 3
  15. #45
    Holland, NY
    635
    Yea I know I wasnt gonna adjust it i just wanted to see if that could be a problem im definately gonna rebuild it and replace the chain and sprockets aand top end so Im gonna start tearing it down hopefully tomorrwo
    TRIKES:
    Dirt Bikes:
    2006 Honda CRF 250R
    SLEDS:
