Results 1 to 12 of 12
Thread: big red 250es tire pressure
    northeast pa
    40
    just wondering what every1 was runing for tire presure on stock 250es tires. it says 2.2 lb's, it just seems alittle low...
    2011 canam commander xt1000 (yellow) extreme frt bumper, headlight gaurds, heated ridin gear on t-stat
    87 trx250r all original
    86 200x (complete restore)
    2009 jeep wrangler rubicon
    Pacific NW
    4,255
    Quote Originally Posted by st222 View Post
    Surprised at no responses.
    Depends on tire type and load weight etc.
    I load my trike, rock it side to side and look for sidewall flex.
    Sometimes 3 psi is enough and sometimes 4.5psi is what I need to keep from rolling (sideways) but I use mine for utility work.
    Flying around the dunes would be be a whole different set of circumstances.
    northeast pa
    40
    Quote Originally Posted by drjoe171 View Post
    i am actually surprised there's no responses!! i thought this was an easy enough ?, but i geuss its not!!!
    but i realize the more weight the more air on something that low of a psi.. i wont be using it for utility work, i have the commander for that. also im talking normal trail riding at slow speeds, maybe 40-50 lbs on the back rack. bin a long time since i was around a big red & now i just got 1. when i had the utility quads i always had 5psi in them no matter what weight.just wanted to see what every1 was using, if they were actually using 2.2 or if some other psi was the magic number.. scott
    May 2009
    S.E. Michigan
    1,251
    For what it's worth, I don't go by pressure. Mostly because I don't have a good gauge that'll read those low pressures. I like to put the rear end up on stands, and then just measure the circumference of the tires and match them. I've got a very narrow tape measure that works really well. I'll hook the tape on a knobby on the centerline of the tire and just rotate the tire around to measure it.
    May 2008
    Northwestern Ontario, Canada
    552
    I keep them at 3 lbs, easy number to read on my gauge. Haven't noticed the ride being any harsher.
    My Trikes...
    -1985 Big Red
    -1986 250r
    -1984 200x
    -1980 110
    -1980 ATC 185
    Sarnia, Ontario, Canada
    3,415
    Since the 250es has a full suspension I like my tires more to the 4-5psi range. Don't need the tires to be the suspension quite as much as say the 200es I used to have that had no suspension.
    Current toys..
    1986 Honda 350X..trail bomb!
    Current non-trike toys:
    1990 Honda TRX300FW
    1995 Seadoo GTX
    1998 Polaris Touring 500
    1998 Club Car (electric)
    Mar 2007
    Texas
    5,045
    i use my foot push test, depending on the type of riding i am doing will determine the pressure so i push both tires on the back to get them clsoe as long as they push int he same with the same force it's good. the harder the ground the softer i run to a point. i will let it push in about 1.5-2" on hard but that's it. if it's soft or more mud i let it push in mo more than 1"
    ________________
    https://www.mikesatvfix.com
    northeast pa
    40
    very good reply's every1, i new you all had own system!! from what i read i;ll prolly go with the 3-4 psi & see how it rides.. just seems to stear hard & buckel with 2.5 in it!! but rides smooth & ive only rode it 4 a mile!!!!!!!!!!!
    northeast pa
    40
    wow, that sounds like little house on the prarie days!!lol ( half pint, get me that stick with the groves in it!!!!!!!!!!!!!)
    250Eddie's Avatar
    250Eddie is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Miami,FL
    395
    What do you do with your ES???.
    On my dads ES we run 3 PSI on each tire for the mud maybe even lower, on my SX with the silverbacks im running 2psi i may just go down to 1PSI due to how freaking hard those tires are lol.
    87-250sx
    86-300es Big Red,The Beast
    85-250sx Tiny SwampThing
    85-250es Big Red
    84-70 ( My Sons Bike )
    Woodsrider's Avatar
    Woodsrider is offline At The Back Of The Pack Arm chair racerFirst time rider
    Feb 2009
    Eastern Passage, NS
    238
    I like 3.5 PSI most of the time....but I find that they work better with 2.5 PSI in the snow.
    northeast pa
    40
    Quote Originally Posted by 250Eddie View Post
    i'll be riding mostly slow trail riding at my buddies house, woods,rocks,some nice trails, some not,just didnt no if the 2.2 lbs of presure rolled the tires to much. i havnt riden my es yet, so i wanted to see what you guys found good!!!!!!!!!!
