Any one come across seeing one of these before? I was browsing YouTube and I came across this cool looking bike. It's a Russian Taurus 2x2 kit you can build yourself, much like the Carl Heald kits I am guessing. It sports 2x2 drive and is lightweight, breaks down to fit in couple small bags for easy transport too. Check out the video and couple links I found.
https://www.youtube.com/watch?v=USHGxDp10D0
some quick specs.
Taurus 2
Axels – 2×2
max . speed 60 km.chas ( a 3- speed version)
Engine 2 x cycle. 5-5.5 hp.
transmission – centrifugal clutch
gears -2 (3)
disc brake on the intermediate shaft
carrying capacity of 180 kg .
Fuel – 1.2 L / hr.
Wheel camera UAZ
wheel diameter – 740 mm .
Wheel width – 220 mm.
tire pressure – 0.13 kg / cm.
Ground pressure min. – 0.04 kg / cm.
clearance – 370 mm .
steering angle of the front fork 55 – degrees.
Seat height – 750 mm.
tank capacity – 5.3 liters.
dry weight – 47-50 kg.
minimum – time showdown 10-20 sec. ( detached front fork )
during disassembly max . – 2-4 min. ( includes two bags in the trunk of the Oka )
couple links for more info.
http://mikeshouts.com/taurus-2x2-terrain-motorcycle/
http://bangshift.com/general-news/ca...d-it-yourself/
